AC not working
Old May 12, 2011 | 06:34 AM
Yougotthehit's Avatar
Yougotthehit
AC not working
Ok I bought this truck over the winter soni couldn't test it.
I bought freon the big tall can with the gauge, filled with new can. The compressor clutch only turns if I spin it with my fingers then it will work and then stops, then I spin it again and it grabs and works. When it works the pressure drops to 45 psi in the gauge when it's not it's at 80psi. I jumped the plug too and it still wouldn't kick on.
Old May 12, 2011 | 07:09 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Your clutch gap is to big. Here is a article that will help you get it fixed.
SpringerPop's Compressor Clutch Air Gap
Old May 12, 2011 | 08:11 AM
Yougotthehit
Ford does not produce that shim kit anymore.
Old May 12, 2011 | 08:21 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
I didn't need it i just took the shim out and my gap was fine.
Old May 12, 2011 | 08:29 AM
bama29fan's Avatar
bama29fan
Same here....
Old May 12, 2011 | 11:24 AM
Yougotthehit
Put the key forward, turned AC to max, went to loosen the bolt and it just spins
Old May 12, 2011 | 12:02 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Try tapping the clutch to make sure that the clutch is engaged. I loosened up the degas bottle for a little more room to work
Old May 12, 2011 | 12:19 PM
bcaughhorn's Avatar
bcaughhorn
Same here. I pulled the clutch and took out a shim. Ice cold air now
Old May 12, 2011 | 07:09 PM
SpringerPop's Avatar
SpringerPop
The compressor shaft spins without the pulley spinning?
Or, does just the bolt spin, and the shaft doesn't?
Is the bolt loose? That would cause it to "spin", and if loose, would also allow the air gap to get way too wide.
Or, are you saying that with the key on and the A/C in MAX, the clutch is not engaging, even if manually pushing the plate in at the time?
What am I missing here?
Pop
Old May 12, 2011 | 09:59 PM
Yougotthehit
Thanks once again to u fellas. Pulled the shim and boom back in Business!!
Old May 12, 2011 | 10:02 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Cool Deal Glade you got it fixed.
