ECT 197, EOT 211, What To Do?
Old May 12, 2011 | 05:30 PM
BLADE35's Avatar
BLADE35
and now that you have the EOTvsECT thing mastered
Watch these IPRvsICP and that will dial you in on your high pressure oil system
ICP = psi pressure
IPR = duty cycle controled percent
If you watch these 2 you will be able to watch for HPO leaks
read this thread for all the recent x-gauges
https://www.ford-trucks.com/forums/1...injectors.html
double check your FICM xgauge here^^ you can dial in your map and boost X-gauges here as well
Old May 13, 2011 | 12:11 AM
Plugman's Avatar
Plugman
Originally Posted by 69cj
I never said that was unacceptable, just a tad on the cool side. You have no problems but if they start dropping into the 180's I would change the t-stat. Diesels use compression and internal heat to maintain efficiency. Too cold reduces the efficiency among other things.
Sorry that was my fault, i believe i misred what you had typed
My thermostat is 2 months old, so i know its good. In fact the more i thought about it i can watch my coolant temps at times climb to 195-198 and then slowly drop down to the low 190's. This is my thermostat opening as my coolant temps drop and hover around 190 correct?
Old May 13, 2011 | 02:44 AM
G550_Capt's Avatar
G550_Capt
Originally Posted by bopfly
Yea, I'm withihn the 15 degree tolerance but the ECT seems high. Part of my dilema is that I've ben doing allot of reading on this forum and now I'm undecided at whether to use VC-9 or Restore and then Ford Gold or Zerex. I will be purchasing one of the coolant filter kits as well and installing as soon as the final flush is complete. Hopefully this alone will drop my ECT which should then drop the EOT.
Hey bopfly
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->You need to use both. Restore is for cleaning out any silicate goo. VC-9 is for cleaning out iron and scale. Use 1/2 gallon of Restore then top off with water and drive it for 20 to 30 miles. Flush it twice. Then use 2 quarts of VC-9 then top off with water and drive it for 20 to 30 miles. Flush 3-5 times with distilled water. Now add 3.5 gallons of coolant and top off with distilled water. This is with the T-Stat removed. When I did it mine my ECT/EOT delta dropped to about 6 degrees.
Old May 13, 2011 | 08:32 AM
69cj's Avatar
69cj
Originally Posted by G550_Capt
Hey bopfly
I would say flush till clear. Some have had to flush more. You can use hose water for a couple of flushes as long as the last two or three are distilled. Helps a little, esp. if you have one of the engines that had to be flushed 6 or 7 times.
Old May 13, 2011 | 12:28 PM
Misky6.0's Avatar
Misky6.0
Yeah, the Ex with the 2nd heater in the rear was a PITA.
Too bad there isn't a way to drain the heater line
under the truck that would really have helped drain the old
coolant.
I'm considering temporarily bypassing the heaters on my next
flush and just flushing the ENGINE several times.
Then flushing the heater hoses/cores by pouring distilled water into
1 heater hose and letting it flow through the heaters and out the
other hose.
Old May 13, 2011 | 05:36 PM
bopfly's Avatar
bopfly
Just checked the codes on the X Guage for the FICM and there was an error, fixed it and it worked great. 47.5 at start up and a steady 46 while running. Sweet! Now on to the flush and coolant filter install.
gt4660
Jun 25, 2015 05:11 PM
tracyclifton
Mar 6, 2015 05:21 PM
Thenewboss
6.2L V8
Feb 20, 2015 02:22 PM
Mark_in_co
Sep 15, 2014 04:12 PM
jiveturkey692000
Feb 27, 2013 09:12 AM
