Diesel Fumes in Cab during Regen
Edit: If this clamp is tightened down but doesn't expand and contract to the same degree with the rest of the system, it could stretch and become loose once the exhaust system cools down. Just a theory.
Side bar: I have never been opposed to turning a screw or tightening a nut. As a matter of fact, I believe that, when you own something, it is your responsibility to perform whatever minor maintenance you can do on your own. (as long as you know what you're doing). The service department is there for the BIG stuff!
@baylessbell: Great pic, thanks for posting!
jammer
Ditto!
jammer
jammer
Just glad I could help. At least you have something to check and if it is loose you know exactly what to tell the dealer is wrong if you decide they need to fix it so everything will be documented, then they cant give you too much crap or take too long with your truck.
Yeah, that fitting is way up there. I had to lay with my feet facing the rear of the truck and prop myself up on my other arm to reach high enough to get to it. Even then I just could reach it.
I spoke too soon about the ticking noise. It's still there this morning after the drive home from work so I must not have gotten it hot enough yesterday. I did find one of the clunking noises on the passenger side ...the seat belt latch was hitting a panel so I flipped it over where the cloth kept it from hitting..gotta remind the kids to check that next time they get out.
Well, just had another regen and no fumes. The only thing that was strange is that i just had another one. The first one where I smelled the fumes was only 50 miles ago and I drove it almost 20 minutes after I got that message. I assumed it finished because my MPG jumped back up into the normal range. But then I get another regen that lasted about 15 minutes last night. I wish we had an indicator that would tell us % full on the exhaust filter and the DEF so that we could time our trips better. The regens always start when I am pulling into the neighborhood and I'm thinking about taking a jug of DEF on my 800 mile (towing) trip.
Getting back to your regen. Other than the occassional smell and lower MPG, it is hard to tell when it is being done. But I can say I have never seen back to back regens -- unless I terminated the process before the first one was done. My first regen happened exactly at 250.000000 miles. I just happened to look down at the exact moment it went into regen mode and saw the message. The next one didn't happen until I hit 1300 miles. From there, it has been hit or miss seeing them. I haven't read how long a regen is supposed to last because I think there are factors whether it continues to completion or not (like stopping for an extended period in heavy traffic).
#28
Paul from Ford posted the DEF usage rates based on driving styles (towing vs. idling vs. highway). There is a message for the DEF when you hit the halfway point. In theory, you should have plenty of miles left (and associated regens) before you need to top it off.
#29
Fixed!
Pic is not too great, taken with camera phone. The fitting was beyond loose, not even finger tight. A lot of soot surrounding the 1/4" pipe and nut.
This is a LONG reach to get to. If you have short arms, you will not be able to reach the nut to tighten. I had to lay on my right shoulder and stretch my left arm as far as possible to reach the fitting. First finger tightened the fitting (about 5 full turns), then used a 17mm end wrench to cinch down. Because of long reach, not possible to get very tight, but is good and snug.
FUMES are cured!!!
Side note, the dang thing is quieter now. Apparently the exhaust leak was giving off some diesel like noises!
Kudos to baylessbell! Great find!
jammer
FYI: Build Date was 05/10
