Idle Trouble
Old Dec 13, 2002 | 02:18 PM
doc300's Avatar
doc300
Idle Trouble
Old Dec 16, 2002 | 07:45 AM
billman's Avatar
billman
Idle Trouble
Idle trouble started after Ford replaced front engine gasket trying to solve a coolant loss problem. They are trying to find it, but have not solved it yet.
Basically, now start up of engine RPM is about 2000, drops to 1100, and never goes lower. Previously, start up was about 1600 and dropped to 800. It is also kind of "shakes" the truck- not a lot, but it did not do that before. They said they adjusted the timing a bit to get it down to 900, but when I went over there to check it out, the idle drops about 100 RPM if I step on the brake pedal, and it hesitates if I step on the gas.
I know they need to find the trouble, but I need my truck back. Do you think they put something back together wrong or created a vacuum leak somewhere? I am having little comfidence in them because when I went to pick up the truck, they did not have a hose connected to the air pump, and it was missing a support bracket that connected the intake and exhaust manifold.
Thanks for your input.
Old Dec 16, 2002 | 09:40 AM
steve83's Avatar
steve83
Idle Trouble
Which vehicle are you talking about? Yes, it sounds like they created a vacuum leak and you need to call the corporate customer service hotline NOW and report what's going on and the incompetence of the dealership. The timing should NEVER be "adjusted" on a Ford EFI, and every document regarding timing says so. Least of all to correct an idle problem!
Old Dec 16, 2002 | 10:11 AM
billman's Avatar
billman
Idle Trouble
Sorry. The difficulty is with the '95 F150.
