Test codes help!
Old May 10, 2011 | 12:28 PM
NICKknackNICK's Avatar
NICKknackNICK
Test codes help!
I have a 1994 f350 7.5 460 auto
I ran a code reader and got
O: 111 pass
C: 172
R(koer): 332 536 538 632 52
need to kno what to do it has a small mis wont pass smog
Old May 10, 2011 | 02:27 PM
rla2005's Avatar
rla2005
DTC 172 is a KOER code only, not Continuous. In any case the definition is: HEGO sensor circuit indicates system lean
DTC 332 : EGR valve opening not detected.
DTC 536: Brake On/Off circuit failure / switch not actuated during KOER test
DTC 538: Insufficient RPM change during KOER dynamic response test/ Operator error
DTC 632: Overdrive cancel switch not changing state
The last code you listed is invalid, you will not receive a mix of 2 or 3 digit codes.
Codes 536, 538,632 are user induced.
Codes of interest are 172, although I question when it was displayed, and the Code 332. Is the vacuum supply line and EVR hooked up to the EGR valve?
Old May 10, 2011 | 08:26 PM
EPNCSU2006's Avatar
EPNCSU2006
172 can be a memory code, according to EEC IV 3 digit codes
Definitely focus on the 172 and 332 codes - both are directly emissions related.
Old May 10, 2011 | 08:46 PM
NICKknackNICK
Thanks guys ill look into the vacuum hook up
EdClavell
1997 - 2003 F150
Jun 16, 2007 06:53 PM
live2hunt
1983 - 2012 Ranger & B-Series
Apr 3, 2007 09:02 PM
nobodyspecial
18
Feb 3, 2007 10:05 AM
91ford_ranger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 29, 2004 11:42 PM
Mark Kovalsky
Jan 5, 2002 07:27 PM
