Sponsored by: Auxito
WONT START IN PARK
Old May 9, 2011 | 09:28 PM
chris5301's Avatar
chris5301
WONT START IN PARK
OKAY, IVE ALREADY ADJUSTED THE SHIFT INDICATOR AND MY TRUCK STILL WONT START IN PARK AND WHEN IN PARK THE INDICATOR IS BETWEEN PARK AND REVERSE. IM ONLY ABLE TO START IT IN NEUTRAL. I ALSO TRY TO SHIFT IT INTO 1ST GEAR BUT I CANT. WHAT DO I DO?
Old May 9, 2011 | 11:43 PM
Lime1GT's Avatar
Lime1GT
Adjusting the shift indicator has no effect on neutral safety switch. It only is adjustable to line up the letters in each specific gear. I doubt your problem is the neutral safety switch located on the transmission since you say you have no 1st gear. I'm more inclined to think it's the shifter tube bushings worn or clamp bolts have come loose. The tube could also be cracked. Here's a link I found for another post. Funny, in what appears to be three column shift problems posted in 2 weeks here on this forum. https://www.ford-trucks.com/forums/9...shing-set.html
trophy_fish
Apr 5, 2016 08:05 PM
Hoss5504
May 8, 2015 12:09 PM
midsouth
Oct 21, 2011 07:39 AM
tzittle
Nov 1, 2000 02:24 AM
