High EGT
Old May 9, 2011 | 05:39 PM
Rat-ler's Avatar
Rat-ler
High EGT
Well took the old truck in today to see if I can find out why I high egt, Got a K&N cold air, so I'm getting enough air in, Got a 4" tubo back exhaust. The only thing came up was a bad map sensor, got one ordered we will see if this help's. Pulling a 2000 boat egt runs around 1100 to 1200, pulling a 35' fifth wheel around 15,000 any where from 1300 to 1600. Can't find anything else wrong, unless someone has the same problem and found a cure.
Old May 9, 2011 | 07:12 PM
bismic's Avatar
bismic
You are asking for trouble running over 1350 IMO. Hopefully you slow down when you are 1400 and over?? For VERY short bursts 1400-1500 may be OK, but not for long ..... and 1600 - wow!
Old May 9, 2011 | 07:21 PM
Rat-ler's Avatar
Rat-ler
I do keep a eye onthe temp, I hope the new map sensor will help the problem
Old May 9, 2011 | 09:34 PM
kenlippold's Avatar
kenlippold
What are you using to monitor your EGT's? Is there any possibility something could be going bad. What are you showing at idel? How long have you had the set and did it show resonably correct reading initailly?
