oil temp
Old May 9, 2011 | 04:33 PM
MAD's Avatar
MAD
oil temp
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--> Hi Guys
What’s up with this oil cooler issues with the 6 I have been having problems whit that little wrench icon coming on lately and have been told this cold be and indication that the oil temp is to hi., I have 71,000 on the truck now. What do you think?
Thanks
Old May 9, 2011 | 04:42 PM
ljutic ss's Avatar
ljutic ss
The codes have to be read to determine what trouble their pointing to. Take your truck to a Autozone and they will read the codes for you.
Old May 9, 2011 | 05:12 PM
BLADE35's Avatar
BLADE35
They sell scangauge at autozone too 160.00 and will tell you alot about your 6.0
check it out here
www.scangauge.com
look inside your coolant bottle for oil residue
Old May 9, 2011 | 06:36 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Do you still have warranty left? Let them deal with it.
