Backfiring
Old May 9, 2011 | 01:16 PM
sams6.9's Avatar
sams6.9
Backfiring
trying to figure out why my 86 6.9 all of a sudden has gone to backfiring out of the intake. it started doing this saturday and i towed it back home cuz it was making some very weird noises. and my air filter looks like someone took a torch to it.
Old May 9, 2011 | 01:23 PM
snaponprofile's Avatar
snaponprofile
What does the fuel filter look like inside? Plugged up I bet...
Old May 9, 2011 | 01:29 PM
sams6.9's Avatar
sams6.9
ill check that. if i remember right the ford house put a new one on it last oil change.
Old May 9, 2011 | 02:58 PM
Aune163rd's Avatar
Aune163rd
Whoa....backfiring out of the INTAKE?! thats not good, I would recommend checking the fuel filter, the fuel system in general to be honest. That could cause any number of problems if its plugged or damaged from something that got into the tank and sucked through the lines.
Old May 9, 2011 | 04:37 PM
Phy's Avatar
Phy
A head gasket blown between adjacent cylinders could let one cylinder fire when the adjacent one is on the intake stroke.
A leaky intake valve could let combustion pressure back into the intake.
Somehow combustion pressure is getting into the intake...
A compression test would help find either of these conditions.
Old May 9, 2011 | 05:51 PM
Aune163rd's Avatar
Aune163rd
good point Phy, I would venture a guess @ cylinder number 7 having a blown head gasket XD! Seems like Lucky ol' #7 is a problem with these engines.
Old May 10, 2011 | 12:27 AM
eatont9999's Avatar
eatont9999
Blown, melted, burnt valve perhaps?
Old May 10, 2011 | 03:54 AM
Aune163rd's Avatar
Aune163rd
Maybe he slung a rod, the thumping would be explained by that.
Old May 10, 2011 | 02:47 PM
sams6.9's Avatar
sams6.9
ok so i checked the fuel filter, it was new went ahead and put another one on it for good measure. compression checks out at 360-371 psi between all 8 cyl. truck only has 126K on it also i forgot to mention it has no cold starting problems at all. this just happened overnight. possibly the IP has gone bad and has thrown the timing way off? jumped time maybe but how?
Old May 10, 2011 | 03:07 PM
snaponprofile
I am pretty sure that said fuel before?? I thought you were saying that the FF looked burned, sorry.
Old May 10, 2011 | 03:38 PM
Aune163rd's Avatar
Aune163rd
lol good one Snapon. If the IP had thrown its timing too far advanced there would be noise coming from the engine.
Old May 10, 2011 | 04:25 PM
snaponprofile
No, I was saying that I thought he said the fuel filter was burned up, not the air filter. The engine wouldn't pop like that if it was too advanced, it would sound like a power stroke.
Old May 10, 2011 | 04:35 PM
Phy's Avatar
Phy
Wow, that's weird. I don't know how it could be backfiring into the intake with good compression all around...
The inside of the air filter was burned?
Is it backfiring consistantly, like a specific cylinder?
Old May 10, 2011 | 05:30 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
how does the CDR look?
did you feel the injection lines and notice a much hotter one than any others?
Old May 10, 2011 | 05:32 PM
PLC7.3's Avatar
PLC7.3
A weak valve spring could do it........ mine crackled out the exhaust when one exhaust valve broke a spring.
I would pull the valve covers and check for a bad valve spring......or rocker assy. If an exhaust valve does not open engine will force combustion into the intake on next stroke... so I'm told.
