Sponsored by: Auxito
Gauges stopped pegging
Old May 9, 2011 | 11:58 AM
jest2525's Avatar
jest2525
Something is bugging me...
I've had my 2003 Heritage about 4 years now. Right after I would crank the key and the engine would start, along with all the idiot lights doing their usual flash ALL the gauges would also fully peg from left to right, then settle back down to their rightly location. A couple of months ago I noticed that the guages stopped doing this. It was suggested to replace the battery which I did. That had no bearing on the problem.
Any thoughts?
Old May 9, 2011 | 01:34 PM
brokenleg's Avatar
brokenleg
But the battery did have something to do with it. when the battery is just a bit weak, the gauges will do that.
Old May 9, 2011 | 08:43 PM
jest2525's Avatar
jest2525
So you're telling me that for the first four years I had the truck and the gauges pegged all that time the battery was bad... not likely.
Thanks for trying though.
Old May 9, 2011 | 09:33 PM
brokenleg's Avatar
brokenleg
My truck did it too. and the battery would start the truck. I charged it. and after that the gauges quit pegging. Im not trying to tell you anything. I am telling you. and if you search "pegging gauges" you will find the same answer what I told you. I dont know the reason. but I suspect the electrics are very sensitive. and what used to work does not apply to todays vehicles. I suspect its not what you want to hear, but thats how it is.
Old May 9, 2011 | 09:37 PM
Podaso's Avatar
Podaso
The heritage might be different, but I've never seen or heard of the gauges purpously pegging on these trucks.
Old May 9, 2011 | 09:41 PM
brokenleg's Avatar
brokenleg
Now you have.
Old May 11, 2011 | 11:13 AM
swillett's Avatar
swillett
bad ground?
Old May 11, 2011 | 01:52 PM
Bluegrass 7's Avatar
Bluegrass 7
A drop in voltage to the dash for any reason can cause the gauges to peg.
A brand new truck with a loose ground could do it.
Dirty battey cable connections.
Bad battery intercell connector.
To low a charge rate.
Leaky alternator diode stack.
Drain from another circuit etc.
Take your pick.
Old May 11, 2011 | 05:11 PM
steve(ill)'s Avatar
steve(ill)
bluegrass is right. MOST Of the time its a low battery or old battery, but could be corroded ground strap, rusty anchor bolts, etc.
1979camperspecial
Jul 22, 2014 12:08 PM
jayro88
Jan 3, 2014 09:00 AM
jayro88
Jan 3, 2014 06:43 AM
Haymanwolf
Jan 16, 2007 03:18 PM
hgall
May 14, 2004 09:27 PM
