2003 Excursion V-10
Old May 9, 2011 | 06:30 AM
crfrider's Avatar
crfrider
2003 Excursion V-10
I am receiving 5 error codes. P1000, P0720, P0722, P0303, and P0316. This all started after we received a few days of heavy rain. The vehicle sat parked for a week or so. Any help will be greatly appreciated.
Old May 9, 2011 | 06:36 AM
tdappleman's Avatar
tdappleman
Was the truck driven through standing water or just rained on? The P1000 is an emissions not ready code which can only be removed after a specific drive cycle is completed. It usually means the battery was disconnected recently or codes have been cleared and the drive cycle has not completed yet. The P0720 and P0722 are speed sensor codes and I would bet are due to moisture and not an actual failure. The P0303 is a cylinder 3 misfire and P0316 is the crankcase position sensor. Water sometimes gets past the hood seal at the cowl and can drip onto the coils causing problems. If you aren't having any drivability concerns, I'd get the codes cleared and see what comes back since they all came at the same time.
Old May 9, 2011 | 06:40 AM
crfrider's Avatar
crfrider
Just rained on, over 4 inches in 2 days. It is skipping and sputtering, especially when idling and when the throttle is held in a steady position. The engine will die completely after it is warmed up and you come to a stop.
cutlass
13
Mar 11, 2024 11:59 AM
gesb123
Oct 29, 2014 08:46 AM
79 bronc
Feb 21, 2012 08:21 PM
shaggy_rc
2004 - 2008 F150
Jun 26, 2011 08:58 PM
SwanBay71
Apr 2, 2010 11:01 PM
