m50d oil
Old May 8, 2011 | 10:44 PM
octaneforce's Avatar
octaneforce
m50d oil
i changed the oil in my mazda 5 speed when i did my clutch last week. someone had told me that it takes 4 quarts of atf. i put in 4 quarts of valvoline fully synthetic atf. ever since then, its been smelling like tranny fluid every time it gets warm. i was just skipping through my chiltons manual and it says that the m50d takes 7.6 quarts. could i have done any damage by running it 3.6 quarts low? i put about 300 miles on it like that. that probably explains why it smells.
Old May 9, 2011 | 01:19 AM
SideWinder4.9l's Avatar
SideWinder4.9l
I don't see how....I mean, it was roughly half full....I need to add 4 qts to mine....
Old May 9, 2011 | 11:15 AM
octaneforce
well its still shifting fine and everything, so i think it should be okay.
Old May 9, 2011 | 03:59 PM
thechief66's Avatar
thechief66
Actually the spec is for 7.6 PINTS, not quarts.
Old May 9, 2011 | 04:27 PM
jas88's Avatar
jas88
Spec, schmeck. On a manual trans or xfer case or rear-end, you fill until it runs out the hole, then you are done and not before.
My experience with the M5OD is it takes about 3.5 qts to fill it - if you put 4 qts in, it should have been running out on the floor.
Old May 9, 2011 | 04:50 PM
thechief66's Avatar
thechief66
3.5 quarts is 7 pints...
Old May 12, 2011 | 08:54 AM
octaneforce
sorry for the delayed response, but i wasnt using the truck for a few days. i finally got around to checking the trans fluid. i went to put in another quart but it was already filled to the hole. i read my manual wrong. thanks for clearing it up!
