Why
Old May 8, 2011 | 10:37 PM
wally29's Avatar
wally29
Why
I just rebuilt the top end of my 2002. And now it seems like there's no fuel pressure.
Old May 8, 2011 | 10:44 PM
onelionhunter's Avatar
onelionhunter
By rebuilt, do you mean all new seals/orings/fuel sleeves, etc? If so, cycle the key at least 3 times to refill fuel bowl and purge as much air as possible. After that, run starter at 20 second intervals with 15 minutes or so between to cool starter untill all the air works out. Sometimes it takes a while to get all that air out once it has been opened.
Old May 9, 2011 | 10:20 AM
wally29's Avatar
wally29
Rebuilt it all. And I have drove the truck down the road several times. However when I start the truck it idles really rough. And sometimes dies on several occasions. Until it is all warmed up. And even then the truck will sometimes die out going down the road.
Old May 9, 2011 | 10:29 AM
SpringerPop's Avatar
SpringerPop
"Rebuilt it all" doesn't tell us a thing. Did you have the heads off? Did you replace the injector cups? What?
Be a LOT more specific, and you'll get much better answers.
Pop
Old May 9, 2011 | 01:16 PM
orng1's Avatar
orng1
Are the glow plugs working?
Old May 9, 2011 | 04:41 PM
Layson's Avatar
Layson
Do you have a fuel pressure gauge? What about a HPOP gauge?
Old May 9, 2011 | 08:02 PM
wally29's Avatar
wally29
I had the heads off, turbo, Injector cups, Injectors, Glow plugs, Oil cooler, Everything. No there's no fuel pressure gauge or HPOP gauge. I bought the Injectors from Diesel care and Performance out of Millington Tennessee. And they sent new glow plugs with the injectors.
