Passenger door
Old Mar 22, 2003 | 08:11 PM
Suerae's Avatar
Suerae
Angry Passenger door
I arranged for some body work to be done on my son's 99 Ford F150 extended cab truck. The work was done on the passenger side back door due to someone backing into it at the bottom back of the door. All looked good when I picked it up last week. However the next day when I was leaving for work in my own car I thought that the passenger side door on the truck was not closed tightly. I looked closer and have found that it is not flush against the back (side of bed) nor is it flush at the top with the roof (off by 1/4 to 1/2 inch). It seems to hang straight and is flush against the front passenger door. Supposedly a new door was too have been installed. It doesn't rattle when driven but when you tug on the door it definitely is not tight. I'm not sure what will happen if it is in the rain-though the seal looks good. What would be causing this problem? My son is out of the country and I wanted to get it fixed right for him and it isn't.
Old Mar 22, 2003 | 08:40 PM
Carlene's Avatar
Carlene
Admom
Passenger door
It probably just needs some adjusting, but I'd take it back to the ones that fixed it and have them make it right.
