79 f250 steering
79 f250 steering
I am evidently in need of a steering box for a 79 250 supercab 4x4. I was cruising down the road and lost most of my power steering. I can tell it is trying to work a little.
So far, I have jacked the truck up and turned the wheel....no better
ensured proper fluid level and belt tension
intalled a reman pump....no better
greased entire frontend...no better
ensured hubs are unlocked and case is in 2wd
The only thing I can think of is a blown seal inside the box. I added some fluid a week ago(1/3 pint) now this. I was actually going straight when it happened. I seems slightly better turning to the right than the left.
Any ideas? Never had anything like this happen. Thanks in advance.
I would put a gauge in the high psi line and see whats going on before doing anything. Rebuild kits are cheep. I'd fix what I have because you probably aren't going to get a good used one, even if you find one I'd still rebuild it before putting it in.
suzanne9273
May 1, 2009 09:34 AM
moonley
24
Apr 8, 2005 12:35 PM
smoove_d
Oct 22, 2004 07:26 AM
79_250RangerLariat
Jul 24, 2003 12:52 PM
