Cab-Over Camper Needs
Old May 8, 2011 | 07:33 PM
idea man's Avatar
idea man
I've searched and can't quite find what I am looking for here.
What do I need to add to my new Super-Dupty to handle one of these cab-over camper things? It looks like we are going to end up in the 2300 pound camper range in order to fit the family. This is a SRW F-250 with the 6.5ft bed.
Just airbags? Add a leaf spring and pre-stop? Adjustable shocks?
All help is appreciated.
Old May 9, 2011 | 05:52 AM
capt caper's Avatar
capt caper
My Lance weigh's in at 4K loaded with water,etc. A 250 6.2 would handle yours o.k. with air bags. No shocks are needed. But I fear your case might be like mine in that the sticker on back of my Lance says dry at 2100lbs but in reality it's 4k. I weighed it on a Cat scale a few times with the camper off then on.
A 350 would be in order and a 6.7 if your going to be using it alot.
I originally had a 250 5.4 gasser then traded up to a 7.3 350 because of the weight and how the enging/trans had to work so hard.
The 6.7 doesen't even know it's on the truck.. This truck handles the camper better then my 02 F350 7.3 with Rancho adjustable shocks,air bags. So just air bags is all you need. Don't get Timbrens I had them on this year and took them off.
hope this helps.
Old May 9, 2011 | 06:04 AM
nitrogen's Avatar
nitrogen
ideally the camper special option package. rear sway bar, upgrade the front swaybar if there is a heavier one out there. shortbox you don't want too much camper behind the taillights. so look at where the water and sewage tanks are so you don't make the steering axle light with weight transfer. what is the actual gvw on the door sticker,2300 plus fluids may not leave you much or any weight for passengers etc.
Old May 9, 2011 | 09:23 AM
dchamberlain's Avatar
dchamberlain
Realistically, that is where the biggest problem will be. Most campers are designed and the weight is distributed for an 8 foot bed. They do make campers for short boxes, but they are pretty rare. I know people who have put campers designed for an 8 foot bed into a short box, but it's my opinion that it's very dangerous. You end up with the weight distribution all off. Weight too far back to be safe.
Just my opinion.
Old May 9, 2011 | 12:55 PM
idea man's Avatar
idea man
Shorty
Thanks for the responses.
Yeah, the shorter bed was all I could manage around town. We'll have a good 600 pound in the cab whenever we have the camper on which might help balance things out. Yeah, stretching the camper out over the tailgate will be the strategy I think. Not crazy long, just 8 feet or so.
So, just Airbags?
Old May 9, 2011 | 04:52 PM
kereams's Avatar
kereams
Originally Posted by capt caper
M Don't get Timbrens I had them on this year and took them off.
What did you not like about them?
Old May 9, 2011 | 07:23 PM
mhoefer's Avatar
mhoefer
Camper option is available on f350 with the overloads and the rear sway bar. You want a newer camper meant for the short box with forward tanks. I would stay shorter than 8 ft for sure. Remember a camper on an sd is up high, try and rent first, see how you do. Big draw back is paking everything up to go fpr a drive. A travel trailer is better IMO. I know i had a camper for my old f350. The other thing is being a contortionist to get in and out of that big top bunk with no head room. I am 6 ft tall and 200 and its not a nice experience. Add to that a family and its oretty cozy, a small tt will also be better value. Only down side being you cant tow a boat too. Small boat on roof rack? Really, rent a. Camper first.
Old May 10, 2011 | 05:31 AM
capt caper's Avatar
capt caper
On my F350 with my Lance which is made for shortboxs and doesn't have a slide out compartment and with 4000k my rear end still sags so my headlights are in the air alittle. Not bad but I get flashing from on coming cars under the right cercumstances.
When I had the bags on my 08 F350 It would get up nice and level. I added more spacers from Timbren but not every little bump with out the camper I hit bottoms right out hard being I have only a 1/2 in or so and the camper is still not level.
So like everything else using this stuff depends on your rig. But airbags definetly work and I'll be going back soon as the season comes.
Timbrens are a quick and cheap solution for some but not for me.
Also with my tanks empty the camper still sags. My 33 gallon freshwater is up front.
Old May 10, 2011 | 08:23 AM
nitrogen's Avatar
nitrogen
springs are supposed to sag as more weight is added. unless the springs are worn out, or the load is significantly in excess of manufacturers limits, this should not degrade the quality of ride or handling, beyond what is normal for a loaded truck. simple solution to headlight issue is to get a t handle wrench in the right size and turn the headlights down 1-3 turns when camping. the gvw on my 05 F350 4x4 cc longbox diesel is 11,200 or 11,800. with the 2 of us, the dogs, and a fully loaded 8foot scamper i have about 800 lb's to spare. no suspension mods of any kind, with the factory camper special option there is no sway or any issue with bottoming, in fact i find the ride is generally smoother loaded up than empty. i can drive through mountain switchbacks marked at 20 mph, at 30-40 and it rides so nice and controlled the wife doesn't even look up from her book.(and she is not that big on driving wildly) i do get the odd headlight flash but not often. i think its time i get me a wrench
Old May 10, 2011 | 09:43 AM
mhoefer's Avatar
mhoefer
Agreed, the camper option is the way to go, but the OP has a f250 so he doesnt have the spring rate or the larger rear blocks and even with air bags he is mostly on the bag and will not be ideal for a camper IMO. He is shy about 1500 lbs gvw and rawr. This will especially be interesting from a handling oersoective if he cant get a camper with most weight up front, with weight behind rear axle will lift the front even more. This is why both my trucks were f350, for the camper package, overloads, possibility of camper or heabier 5th wheel. Just saying, maybe he should entertain a tt or atleast test a camper first. I would also consider airbags over timbrens for the travel issue and i would go one more and have front and rear bags with a 250 if i was towing a heavy camper and boat. The handling will be more predictable IMO.
Old May 10, 2011 | 09:51 AM
nitrogen's Avatar
nitrogen
most likely he can get away with it, but its not going to be as stable as desirable. worst case scenario, that reduced stability leads to an accident and someone he loves dies. my truck is definitely large, and i prefer not to take it downtown in the big city. my preference isn't even my motorcycle, its my wifes bike 600 ninja way more fun downtown than any sports car. that said i can and do take the truck downtown during rush hour if i need too.i hate to say and don't want to sound nasty but if the longbox intimidates you that much more than the shortbox maybe any superduty is too much vehicle for you. or go to a truck driving school for a couple hours just to have them teach you maneuvering
Old May 10, 2011 | 11:31 AM
capt caper's Avatar
capt caper
It's more then that. You need to keep the center of gravity level for the camper. With the rear sagged you'll be throwing off the center of gravity of the camper which Lance has designed in to be when truck is level.
Air bags acomplishes this.
You guys can do what you want and depending on your truck/rig it will depend but with my E Ply 18in tires and F350 with air bags the truck is stable and safe. I only have SRW as well. Been using it this way since 03 with loads of miles on it and just came back from a long trip. This 2011 is the most stable I've had out of the 01 F250 and 02 F350. My 08 was the same as the 2011 is. I used stock shocks on these last two with air bags only.
Old May 10, 2011 | 11:57 AM
nitrogen's Avatar
nitrogen
obviously what cap is doing is working for him. my point is some sag is normal. excessive sag i.e. bottoming out is not not good. that is why our trucks are higher in the rear than the front when empty. put a load on and it come to roughly level. now if the springs were sacked out or just plain overloaded then air bags would lift it back up. what they won't do is reduce the actual weight on that rear axle. they will not transfer weight to the front end. go on try it, take your air bag truck down to the scale with your camper. get both axle weights with and without air. the change will not be significant. so if you still have excessive rearward weight bias going down the road, think about what happens when you make an emergency stop or have a tire failure. now you have much more weight transfer to the front end than the engineers planned for. say maybe you are not exactly running in a straight line at the time, huge changes in steering geometry. very exciting
Old May 10, 2011 | 06:44 PM
cabindoc's Avatar
cabindoc
IMO install Firestone Ride Rite airbags to level things out. I also agree with some of the guys on TT rather than in bed camper, unless you need to tow that ski Natique every time...
Pictures of our very roomy, off road pop up for our family of 4. And we can still take some toys to play with. BTW, this pic was taken when I had a 350 w/o airbags. I added the bags after this trip.
Old May 11, 2011 | 07:09 PM
idea man's Avatar
idea man
Nice set-up.
We have been going back and forth between the trailer seen above or maybe a pop up camper or a traditiional camper. Renting seems like a very good idea. I have no idea where they would rent campers, but it would be worth looking into.
Apparently Coleman has gone, or is going, out of the tent trailer biz and these trailers are almost reasonably priced. That would also leave room for the bikes in back.
Looks like I need to get me some air bags and a maybe a wrench and go from there. Good stuff. Thanks
garryk6
Jul 2, 2017 05:35 PM
maddyforford
Modular V10 (6.8l)
May 1, 2017 03:01 PM
maddyforford
Apr 28, 2017 12:28 PM
spikedog
General Automotive Discussion
60
Dec 10, 2013 08:05 PM
alvald83
Sep 19, 2012 09:11 PM
