What engine will fit 03
Old May 8, 2011 | 05:26 PM
john11139's Avatar
john11139
I hope by the last of the week, I am into my locked engine to see if it is junk or not. But I decided to try and get some answers before then so I dont have to do info searching then. I understand that a 04 engine is different that a 03. I have located a short block, for $800 and the fellow says he is not sure it is a 03 or 04. Can you tell by the serial numbrs? I have heard of fellows having a 04 truck but found out it had a 03 engine. Second choice is I found a complete 04 ( again might be a 03 out of a 04) 35k miles, complete with turbo, wireing harness, ficm, (probably wont work on mine because mine is a std trans) for $2k (looks clean) What will I thave to take off mine to make it works. Will the 04 sensors and every thing work? If mine is junk, I am leaning more toward the complete low miles engine as I can get $500 for my turbo and same for each head. How can I indify the engines?
Old May 8, 2011 | 06:50 PM
BLADE35's Avatar
BLADE35
hope this helps
Page 8 Overview: engine Serial Number, FICM Cal Label, Emissions Label
Old May 9, 2011 | 05:27 AM
john11139's Avatar
john11139
Originally Posted by BLADE35
Yes, but how do I interpt those numbers. How do I tell what year is a 03 & 04 and will they interchange?
Old May 9, 2011 | 06:25 AM
npccpartsman's Avatar
npccpartsman
03 has the ICP and IPR sensors under the turbo. 04 has a sensor (ICP) in the passenger side front of the valve cover.
Old May 10, 2011 | 06:46 AM
john11139's Avatar
john11139
But if I go look at a short block, it will not have any valve covers on it. If I go to Ford, could they tell me by the serial # on block when the 04 numbers started?.
Old May 10, 2011 | 11:36 AM
BLADE35's Avatar
BLADE35
well if you can get the serial number,try to call ford parts see if they can pull for you like your ordering a part IDK
if you get a short block as long as its a 6.0 short block should work Its a long block I think you will have to be more careful on witch one it is
Old May 10, 2011 | 04:22 PM
cheezit's Avatar
cheezit
the oil pump set up and branch tube may be a lottle different.
