Where's the best place to find a replacement engine perch for a '66 FE (352) f100. Does anyone sell aftermarket versions. From what I've read if I ever intend to add PS(Saginaw) or AC it might behoove me to look for perches from a '73 f100. Is that right?
No, your current perch will work with some modifications. It is not 100 percent necessary.
Or any 1969 F100/350 from serial nnmber D96,001 up ford power (Saginaw) truck equipped with a FE (thru 1976) or I6 (thru 1979) can donate the perch.
The later perch is slightly offset to clear the box. Some cutting of the stock perch will provide enough clearance.
1966/68 F100/250 2WD & 1969 F100/250 2WD before serial number D96,001 = BENDIX P/S / P/S was not available on F350's before serial number D96,001.
---------------------------------------------------------------------------------------------------------------------------------------------------- C5TZ-6028-C .. Right Engine Support (aka tower, stand, perch) / Obsolete
DICKERSON MOTOR CO. in York SC has ONE = 803-684-4225.
ED BENNETT FORD PARTS in Lebanon PA has ONE = 717-272-8762.
GREEN SALES CO. in Cincinnati OH has TWO = 800-543-4959.
Have only had the truck about three weeks so it was the previous owner or before him. Something must have happened on that side because the RH lower shock mount was rattling and cracked. This all explains the sound I was hearing when I went over a speed hump that sounded lluke marbles rolling around a tin can.
John, I will be pulling the perches from my 65 here in about a week and Im pretty sure they are in good shape. Had a 352 in it stock. Shoot me an email @ corwinbos@gmail.com if you are interested.
