RH engine perch
Old May 8, 2011 | 01:38 PM
Spyderjohn's Avatar
Spyderjohn
RH engine perch
Where's the best place to find a replacement engine perch for a '66 FE (352) f100. Does anyone sell aftermarket versions. From what I've read if I ever intend to add PS(Saginaw) or AC it might behoove me to look for perches from a '73 f100. Is that right?
Old May 8, 2011 | 01:43 PM
garbz2's Avatar
garbz2
No, your current perch will work with some modifications. It is not 100 percent necessary.
Or any 68 up ford power (Saginaw) truck equipped with a FE or I6 can donate the perch.
The later perch is slightly offset to clear the box. Some cutting of the stock perch will provide enough clearance.
Garbz
Old May 8, 2011 | 02:02 PM
Spyderjohn's Avatar
Spyderjohn
Have a broken RH perch.
Old May 8, 2011 | 02:10 PM
garbz2's Avatar
garbz2
How did you manage to break a perch?
Then a donor i mention above will do the deed. Or just fix the perch.
Garbz
Old May 8, 2011 | 02:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Or any 1969 F100/350 from serial nnmber D96,001 up ford power (Saginaw) truck equipped with a FE (thru 1976) or I6 (thru 1979) can donate the perch.
1966/68 F100/250 2WD & 1969 F100/250 2WD before serial number D96,001 = BENDIX P/S / P/S was not available on F350's before serial number D96,001.
C5TZ-6028-C .. Right Engine Support (aka tower, stand, perch) / Obsolete
DICKERSON MOTOR CO. in York SC has ONE = 803-684-4225.
ED BENNETT FORD PARTS in Lebanon PA has ONE = 717-272-8762.
GREEN SALES CO. in Cincinnati OH has TWO = 800-543-4959.
Old May 8, 2011 | 02:25 PM
Spyderjohn's Avatar
Spyderjohn
Have only had the truck about three weeks so it was the previous owner or before him. Something must have happened on that side because the RH lower shock mount was rattling and cracked. This all explains the sound I was hearing when I went over a speed hump that sounded lluke marbles rolling around a tin can.
Old May 9, 2011 | 09:31 AM
Spyderjohn's Avatar
Spyderjohn
Flange is broken on one of the lower mount points. And upon closer discovery all of the bolts were loose. Yikes!
Old May 9, 2011 | 02:22 PM
garbz2's Avatar
garbz2
Heck, A little JB weld on there she will be fine.. LOL....
Check the places ND listed and snag one of the NOS ones if they are affordable. Time to change it out.
Garbz
Old May 9, 2011 | 08:08 PM
C G B's Avatar
C G B
John, I will be pulling the perches from my 65 here in about a week and Im pretty sure they are in good shape. Had a 352 in it stock. Shoot me an email @ corwinbos@gmail.com if you are interested.
