ford ecm trans controller
I mean I know you would need at least some engine imputs to the computer to make it work, but just how many?
Obviously it would need a TPS, and maybe a speed sensor or something.
I ask because I want to run my e4od on a carb'ed setup.
I don't really wanna spend $600 on an aftermarket controller and harness.
I've heard of guys doing something like this when converting to a mass air setup.
Any info or links would be appreciated.
5.0 and was wondering if you have converted to mass air and if so I need some help with the wiring pin location and such I am real good with wiring just dont want to have to buy to manuals to do it and need to know what I need to get from the bone yard.....if you can help that would be great !
The PCM also uses the PIP signal to be used as an input in determining shift scheduling and (EPC/line pressure).
The PCM also uses the Air Conditioning Clutch (ACC) signal as an input to determine EPC when the ACC is engaged to compensate for the additional load on the engine.
The Manifold Absolute Pressure (MAP) Sensor is used as an input to determine shift schedule and EPC for altitude operation.
The Low Range Switch (4x4 models) is used to Modify the shift schedule for 4x4L transfer case gear ratio.
Transmission Operating Temperature (TOT) Sensor: The Transmission Operating Temperature (TOT) sensor is located on the solenoid body in the transmission sump. It is a temperature-sensitive device called a thermistor. It sends a voltage signal to the PCM. The voltage signal varies with the transmission oil temperature. The PCM uses this signal to determine whether a cold start shift schedule is necessary. The cold start shift schedule lowers shift speeds to allow for the reduced performance of cold engine operation.
Manual Lever Position Sensor (MLPS): Sends a signal to the PCM. This indicates the position of the shift lever (P, R, N, (D), 2 or 1).
