Hi all,
Got a crate motor. (86 4.9) new intake, new exhaust etc..
Instructions on the motor said to use their 2 piece intake / exhaust gaskets. So I did. I have also heard other stories. Like to not use an exhaust gasket at all.
I just did what they said to do and I only torqued the bolts once.
I guess I was supposed to re-torque them after heatin em up. It leaks now.
Was that the big mistake or is that gasket stacking method they recommend wrong?
no sure about the carb'd engines, but for the 89 big six in my bronco when i bought the gasket set for it that gasket was one piece. however it has holes for the extra bolts in the efi manifolds. but I think that a one piece gasket would work better than juggling two.
you could try re-torquing them if the leak is minor, i don't agree much about not running the exhaust gasket since the intake and exhaust are bolted to each other, seems to be a good way to get both exhaust and vacuum leaks.
The one piece exhaust manifolds on mid-'80s 300s all leak and work themselves loose. You can use EFI manifolds, a pair of 3-into-1s with a little fiddling, and be pretty much done with the exhaust manifold nonsense. If you think that might be for you, there are a couple of threads on here about that.
