Black Smoke
Old Mar 22, 2003 | 03:21 PM
PARHAM711's Avatar
PARHAM711
Question Black Smoke
I HAVE A 1994 EXPLORER LIMITEDWITH 4.0 V-6,WHEN I START THE ENGINE IT RUNS VERY ROUGH AND PUFFS BLACK SMOKE LACKS POWER.SOMETIMES IT WILL CLEAR UP AND RUN FINE I RAN A SELF TEST WITH THE CODE SCANNER AND REC'D CODES 558,112,215,812 COULD ONE OF THESE PROBLEMS EFFECT THE OTHERS AND WHERE SHOULD I START REPLACING PARTS OR SENORS ETC.THE ENGINE WAS TUNED LESS THAN 2000 MILES AGO AND WAS DOING FINE,ALSO WHERE WOULD I FIND THE EGR VALVE REGULATOR SOLENOID(CODE 558)?PLEASE HELP!
PARHAM711@NETZERO.COM
Old Mar 22, 2003 | 04:02 PM
ckrichard's Avatar
ckrichard
Black Smoke
P0112- IAT or ECT sensor reference signal too low
P0215- Unknown code
P0558- EGR cacuum regulator circuit failure
P0812- Unknown code
WHERE WOULD I FIND THE EGR VALVE REGULATOR SOLENOID?
It is going to be on the back, drivers side of the engine, behind and below the number six injector. If you can still not find it tell me and i will try to find a diagram of it. Oh, one other thing the egr system was only requred on the calf. models.
Chris
mah77
Sep 24, 2011 12:07 PM
bpardo191
Aug 27, 2011 09:22 PM
fastbmw01
19
Jul 29, 2011 12:36 AM
mudbug3854
Nov 29, 2010 03:37 PM
LarryBee
Jan 16, 2007 04:59 PM
