I was just going thru some stuff I had laying around, and I found a box with some new, what I believe are power steering hoses/lines for a 4x4. They are NOS Ford pieces, part number D3TZ-3A714-B. At first I thought that they were a matched pair for a 4x4, as the lines are much longer than my 74 F350 2wd, but since they both carry the same pt. #, I`m guessing that they are just the high pressure hose/line, so is the return line just hose? Any idea what they are worth? I may just stick em on Ebay and see what the market is, but I`d like to make sure of the application. Thanks.
Those are the right/left turn, power cylinder lines for '73-'77.5 F250 4x4's i.e. Highboys, they're available in the aftermarket for around $35-40ea. being as yours are NOS Ford pieces they may fetch a little more on ebay, or put the word out here, i know a few guys were looking for a set in the past.
Those are the right left turn, power cylinder lines for '73-'77.5 F250 4x4's i.e. Highboys.
Originally Posted by rory428
D3TZ-3A714-B
This is a genuine Ford P/S hose, not a gypo.
D3TZ-3A714-B .. P/S Hose, Control Valve to Cylinder-LEFT Hand Turn / Use with GARRISON Power Assist P/S / Obsolete
Applications: 1973 F250 4WD 360 / 1974 F250 360 before serial number T80,001.
1974 F250 4WD from T80,001, 1975/77 F250 4WD = Bendix Power Assist P/S.
You didn't get this info from any Ford truck parts catalog, but from an autoparts store catalog.
The gypo (aftermarket) hoses like this do not have a right or left hand turn, so can be used on either side and...are longer.
Here is the other hose in this location that has the same application as D3TZ-3A714-B = D3TZ-3A717-B .. P/S Hose, Control Valve to Cylinder-RIGHT Hand Turn / Obsolete
Rory: You want to know what this puppy is worth? Call GREEN SALES CO. in Cincinnati OH (800-543-4959), they have ONE. No Ford Dealer, no other obsolete parts vendor has any.
Any idea what size ends are on the line?? I have these lines but they are females I am having a hard time getting the right fitting. I know it is pipe thread 1/4 into the valve but the females are different.
"NOS ONLY" in Cali now has (1) as well. But in all truth these are easily made at your local shop (if they're worth a damn), and usually for much cheaper.
So, unless this is a Concours resto, go the cheap, easy, fast route.
