speedo gear ?
Old May 6, 2011 | 05:22 PM
MIKES 68 F100's Avatar
MIKES 68 F100
speedo gear ?
my 68 speedometer is way off , i have 275/60/15 tires on there any one know what tooth gear i need or the calculation to figure it out ?
speedo says 40mph when i am driving with traffic at 60mph
thanks
in advance
mike
Old May 7, 2011 | 04:06 AM
jowilker's Avatar
jowilker
Mike, I would suggest that you get under the truck, go with a 3/8" wrench and pull the speedo gear as an early thing to do. Count the number of teeth on the gear. A single tooth +/- is good for about 5 mph. Your's seem very mis-matched.
If you can get on a level garage floor, mark the lr tire at floor contact, hand rotate the tire one rev. while counting the revs of the drive shaft. That will give you absolute ratio, to help work this out.
When I used to go yarding I picked up gears still hanging or laying near a tranny pull. New ones are still available or maybe you can get a used one.
John
Old May 7, 2011 | 04:08 PM
MIKES 68 F100
found this thanks to google
New Teeth = (Current Teeth x Speedo Reading)/Actual Speed.
Ford Motorsports Also Uses This Formula:
Driven Gear Teeth = (Drive Gear Teeth x Axle Ratio x Tire Rev. Per Mile) / 1000.
so guess i have to pull old one to count teeth , i'll use my garmin gps for actual speed
Old May 7, 2011 | 07:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford has used the same nylon speedometer DRIVEN (end of cable) gears since 1960, 16-21 teeth are available, the prices range from 2 to 4 bucks each.
Speedo DRIVE (on the output shaft of the trans) & DRIVEN gears are determined by the axle ratio, trans type and size of the tires.
Old Jun 10, 2011 | 06:36 PM
biggut's Avatar
biggut
So, if my speedometer is reading 10mph too fast, do I need a gear with 2 more teeth, or 2 less?
Scotty's 52 F3
Sep 13, 2015 08:39 AM
MIKES 68 F100
Jul 29, 2015 04:51 AM
d1725829
1978 - 1996 Big Bronco
Feb 25, 2014 10:32 PM
reddnekk
Nov 9, 2012 01:28 AM
ssg510
Modular V10 (6.8l)
Dec 3, 2010 04:43 PM
