Sponsored by: Real Truck
Hello everyone!
Old May 6, 2011 | 04:14 PM
mitce's Avatar
mitce
Hello everyone!
New ford truck owner of a used f250
2003 4x4 with 6.8l
I have an issue and did not know if this was the spot to post for help.
Old May 6, 2011 | 05:42 PM
pbeering's Avatar
pbeering
What is your issue?
Old May 6, 2011 | 07:36 PM
mitce's Avatar
mitce
Pressure relief sound
I bought my 2003 F250 4x4 with a 6.8l used. Ithas 117,000miles on it.
Under load, going up hills or towing, at around 1700 rpms it makes a sound that at first I thought was an exhaust leak. After it passes 1700rpm it goes away.
I found a broken exhaust manifold bolt on the drivers side and relaced all the bolts. The sound was still there.
I then replaced all the spark plugs and boots. The sound was still there.
The transmission went outthe following week and had it replaced with a new ford transmission. The sound is still there.
I also replaced the muffler and had the entire exhaust system and the sound is still there.
I am puzzeled by why it only occures at 1700 rpm. It sounds like a pressure relief issue as it is a spiting sound of air being released.
any ideas
Old May 6, 2011 | 11:30 PM
Super08's Avatar
Super08
None, try posting this down in the V10 forum and maybe someone in there can help if it is engine related.
