so i have a new filter to put on and am just goin to dump fluid and replce old filter its been 30000 since last bendover changing at the dealer so its not that bad, can anyone tell me how many litres of ford tranny fluid i need and what kind? i believe there are 2 for these trucks and mine is an early job 1 with bolt up filter
Mercon LV is what you want to add. I think around 8 ltr.
Apparently the early '08s did use SP and they changed to LV later in production. The OP should confirm what is specified for his particular transmission.
I have the external filter on my truck and a dealer charded me over $400.00 to change the filter and fluid. What do you guys with the enternal filter pay at a dealer?
Service manual says 7.1 L or 7.5 qts. for drain and refill. Torque drain pan plug to 20 Nm or 177 lb-in. Then check dipstick at normal operating temperature and add in increments of .24L or 1/2 pint till proper level in the cross hatch area of dip stick.
I measure what I drain; it is always 8 qts.
I have the later model without the external filter; so the internal filter was changed during the 60,000 mile service per the maintenance schedule.
Motorcraft® MERCON® LV Automatic Transmission Fluid
XT-10-QLV; original spec was the SP
