Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Towing and Hauling Guides
- How to Measure Trailer Tire Pressure
Step by step instructions for do-it-yourself repairs
Tire pressures for tow vehicle
Ditto what the other guys said. Don't exceed the tire sidewall rating.
BUT... According to my 94 user manual and I even think door sticker, there are different inflations depending on whether you are loaded or unloaded(towing).
On my 94 F250 longbed, supercab, that I use to tow, from memory...
Unloaded, the recommended inflation is about 55#. I believe this is for better ride and longer tread wear.
Loaded inflation is something like 85#. This gives you maximum per axle load rating but can wear the tires in the center faster and will ride hard unloaded.
Naturally do not exceed the rating of the tire. Similar tires may have slightly different max ratings. The last set I had, Wranglers had a 90# rating while the current Goodrich TAs are something like 85#, so read the walls and manual.
Good Luck,
Jim Henderson
Good Luck,
Jim Henderson
X2 and X3 on what they have all said before. Remember if you are going up in altitude, you gain tire pressure. As you heat those tires with your load, you increase the tire pressure. Keeping your tires at the sidewall rating, keeps you within the intended tolerances of the tire companies ratings. Also the higher the pressure, the rougher the ride. Another thing is a I have been reading about people using pure Nitrogen instead of good ole AIR to pressure tires. Here is link as to "why" Nitrogen may be a better gas for your tires.
Nitrogen in Tires : Information about Nitrogen Tire Inflation News, Benefits, Generator Dealers, Location Finder & More
the sidewall rating is cold tire pressure!
DO NOT stop and check the pressure while the tires are hot then let some out because they were too high...
If you have a concern, stop and grab a bite to eat, letting the tires cool off, THEN check the pressure. By design, the pressure will increase during travel.
Also, using purer nitrogen is just fine if you don't have to pay any extra for it... the atmosphere is mostly nitrogen to begin with, and cool compressed air doesn't hold much water (it condenses as it cools in the tank and falls to the bottom). As for other molecules being smaller and escaping the compound that the tire is made of... sure, there is truth to that... but that just leads to purer Nitrogen in your tires... so you top them off as necessary and repeat until you've made your own 99% Nitrogen.
Tnriverside
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
29
03-22-2016 02:20 PM
Fuelhog 5212
03-28-2011 08:10 PM
Bigfoot151
07-16-2008 09:01 PM
stein78
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
12-17-2004 01:16 PM
