Hey guys just wondering how to adjust and possibly service the parking brake mine has stoped working for the most part and I really want to fix it so any help would be great
Yeah I kind of figured that there was some thing behind the rotor but can't seem to get the rotor off so I'm going to get a rubber hammer and smack it a few times but once I get that far I have no idea what I need to do to adjust it or replace stuff on it
I've never had to deal with parking brakes till now
So to even get at the parking brakes I have to pull the rear hub apart ?
Nope. They can be adjusted thru a plug on the back of the backing plate. Use a brake spoon or a screwdriver. IIRC you have to spin it up. It's a star wheel just like on drum brakes. They just don't self adjust like regular drum brakes.
Do I have to pull the calliper off to get at that cover ?
Thanks guys I will try and adjust it in the morning and see if that fixes it I will post up what I figure out
Comodown thanks for the pick
When I finally decided that I needed to give the parking brakes a little help it became clear that adjusting wasn't going to help. I turned and turned and there was nothing. So I ended up pulling the hubs and getting em fixed. Pretty easy actually. Read what you can here and you'll have all the information you need. I also used a Chilton book that was a great help. By the way, you will need a special tool to get the hub off, but not a big expense at all. Got mine at the local auto parts store for under $20.
No, the plug just pops off caliper untouched. If you notice the smell of gear oil on the plug or around it your rear wheel seals need to be replaced. If you need to change the shoes though, the seals get replaced anyway!
