Very rough running when cold
Old May 5, 2011 | 09:41 PM
excursionsthebeast's Avatar
excursionsthebeast
Hey guys, got a new problem with my beast. If you dont let it warm up for 10 minutes or more it runs extremely rough. In rough I mean jerky, sluggish, takes about a mile to get up to 45mph, no power. I have a banks programmer on it and if I dont have time to warm it up, when the programmer finally kicks in it runs smooth. I noticed when its rough I can see small puffs of smoke out the exhaust. crank time to start is also a little longer than normal. No lights are on and I just changed the filters thinking that may be a problem. If it sits more than 4 or 5 hours it does the same thing and even in 70 degree weather it does it when first started. After warm up or the programmer kicks in it runs perfectly fine. Thanks for any help.
Old May 5, 2011 | 10:11 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
What motor are we speaking of? Year of vehicle?
Old May 6, 2011 | 08:13 AM
excursionsthebeast
Sorry, wasnt thinking. Its a '05 6ltr. I have already been thru the blown head gasket and put head studs in it. It has all the banks goodys on it. When you start it cold it idles extremely rough for bout 25-30 seconds. And when I say cold starts I am refering to been sitting for more than 5 hours, temp outside doesnt matter if its 20deg or 70deg.
Old May 6, 2011 | 08:23 AM
hkaiser83's Avatar
hkaiser83
Checked the voltage on your FICM lately?
Old May 6, 2011 | 10:53 AM
islander1808's Avatar
islander1808
FICM, FICM, FICM.... Exactly what mine did... Hopefully you extended your warranty... They aren't cheap.
Old May 6, 2011 | 02:00 PM
excursionsthebeast
Dangit, not what I wanted to hear but kinda what I was thinkin. So is this a bolt on and go or do I have to have it hooked to a computer to make it work. Just checked and it $708.00. Not as bad as I thought it would be
Old May 6, 2011 | 02:07 PM
excursionsthebeast
And has anyone tried the refurbed ones people are selling on ebay?
Old May 6, 2011 | 02:52 PM
hkaiser83's Avatar
hkaiser83
Get an upgraded one so it never happens to you again!
Swamps Diesel makes an awesome one!
Old May 6, 2011 | 03:10 PM
islander1808
It is bolt on but it doesn't come programmed. Typically a Ford tech will have to transfer your existing program from the old to new.
Old May 7, 2011 | 09:21 AM
excursionsthebeast
Wow, swamp diesel ficm sounds good. Espesially like the 58v version. Thanks guys for all the help. Ill post when I get it fixed but it may be a little bit till I get the funds.
Shannon Lowman
21
Feb 18, 2021 05:03 PM
lewis racing
Feb 19, 2015 11:55 PM
SuperDuty Bundy
Jun 5, 2014 02:37 PM
Mindy -
Apr 9, 2010 12:46 PM
Jim McCarty
Dec 21, 2008 04:07 PM
