Door belt weatherstrip supplier
Does anyone know a supplier of rear door window belts (the weatherstrip that goes on the inside and outside of the door panel up against the bottom of the window?) I checked LMC and many online truck part companies, they all make the front door, but no body has the rear on an 89 F350 Crew cab.
Thanks!!!!!
Thanks!!!!!
a.) You should try calling them. Online catalogs don't have everything in them.
b.) www.partsguyed.com
c.) find and PM numberdummy... He can give you the OEM part numbers to reference against.
This might help too... If not you'll probably find another good use for it down the line.
Car-Part.com--Used Auto Parts Market
eric8
04-11-2017 12:30 PM
boiler71
07-23-2016 04:50 PM
