Ok, I picked up my truck last night. Like all guys, I look under the hood and, like most guys, I have no idea what I'm looking at (except it's really cool!)
Newbie question: Why does the 6.7PSD have two batteries?
Second newbie question: Since all batteries eventually die, how do you know when one is bad? No start? Slow start?
Last question: Who the heck is tall enough to pull out one of those batteries! (ok, just kidding).
A tremendous amount of current is needed to crank an engine that has a 16:1 compression ratio. The starter alone weighs about as much as a small engine. Secondly the glow plugs will eat up a few amps and the reserve capacity is necessary to crank the motor.
Trust me, if your truck did not need two batteries Ford would not have put two in. Neither would GM or Dodge. Once one needs to be replaced you can change one but you SHOULD replace both....
It is a 12vdc system not 24vdc meaning the batteries are hooked up in parallel and 2 batteries simply doubles the current capacity. Since there is no diode isolation between them the system will draw power from both batteries at the same time. That also means that the bad battery can and will draw the energy from the good one. It is always best bet is to have both batteries at the same potential. (same age, same current capacity) Suggest replacing both of them.
Starwarrior
This is a commonly referenced myth. Compression ratio has very little to do with how difficult it is to turn the engine over, as for each piston that's compressing air that much you have one that is decompressing and acting to assist the engine turn. If the engine took more energy to turn than a gasser, the parasitic losses while running would also be higher and it would be less efficient. As we all know, diesel engines are more efficient.
It takes a LOT of power to complete all the tasks to start these engines up. Glow plugs can draw as much as 35 amps each, the injectors take much more power to fire than a gasser, the engine controls are far more complex, and the thicker oil requires more power to pump in cold weather.
Ever try to turn a Diesel engine by hand? Good Luck. Why do you figure they need a starter motor the size of a Honda engine to crank the sucker over, just to yank the owners crank? 4 cycle 8 cylinder engines have a fixed ratio between cam and crank timing and the higher compression ratio makes a big difference.
Not following this... each cylinder that is decompressing is not 'helping' the engine turn over, it is merely not hindering it. If it's the electronics that take so much juice to start, why do Dodge trucks (without glow plugs) have two batteries? What about 80's and 90's model diesel trucks that are fully mechanical (injectors, oil pumps, etc)? Modern gas engines have just as much electronics on them, but they only have one battery.
If you think that a motor with a compression ratio of 16:1 is no harder to turn over than a gasser at 9:1, you should try doing it be hand!
Great, you got it only glow plugs have nothing to do with combustion other than to warm up the cylinder so combustion can take place when heat is transfered in colder weather. And yes my friend, I have cranked enough cranks in my day, both gassers and oilers.
