What Bellhousing do I need ??
Old May 5, 2011 | 07:47 AM
coldsteel187's Avatar
coldsteel187
I have a 1984 4x4 Ford F-150 it has the straight 6 I want to put a 351W in its place.My truck has the 4 speed standard tranny in it what bell housing will I need,will ones that fit a 302 work or will mine work???I need one my motor is SMOKED!!!!!!!
Old May 5, 2011 | 08:25 AM
f100jim's Avatar
f100jim
Your bell housing from your 300 will bolt right up to a 351W. To swap to the 351W, you will need to remove the 300 motor mount perches from your frame and install 302/351W motor mount perches from a donor truck - junk yard is your best bet. You will also need a 302/351W radiator.
Also remember: DO NOT use the flywheel from your 300 on the 351W unless you want it to shake like hell and crack the crankshaft.
Old May 5, 2011 | 08:32 AM
coldsteel187
So all I have to find is a flywheel man I figured it would be more complicated being it was a Ford.The donor truck is a automatic truck so Ill have to find a flywheel for a standard truck 351 W.Right???The radiator from the donor truck will work Ill plug off the Trans. holes...Thanks BTW you got a flywheel LOL!!!
Old May 5, 2011 | 07:42 PM
cadunkle's Avatar
cadunkle
Flywheel will be 28 oz imbalance. Early 302 flywheel should work. Don't quote me, but I'd imagine the small block trucks take a 164 tooth flywheel, not either of the two smaller ones.
