95 e150 problems
Old May 4, 2011 | 08:20 PM
corytcline's Avatar
corytcline
95 e150 problems
I have a 1995 e 150 has a fuel injected 300 six in it, Problem just started a week ago, when started in the morning it knocks or taps like it is out of oil for about five minutes or so. Then about thirty minutes into my daily drive the oil pressure gauge will peg to max engine light will come on and it starts to surge and run really rough I'm wondering is my oil pump going out or am I having some sort of computer problem?
Old May 4, 2011 | 10:54 PM
Club Wagon's Avatar
Club Wagon
Sorry, been driving since early 60's but never had an opportunity to hear what any motor sounds like when "it is out of oil".
Presume it's filled w/correct amount of oil in good condition & shows normal pressure "for about five minutes"?
Presume by "engine light" you mean Check Engine Light "will come on" & realize that the OBD1 onboard diagnostics should 'throw a code' that can be read to reveal the fault?
If it was mine I'd take advantage of OBD1 & check for the fault code. Most parts stores will do this for free, while you wait, if you don't want to own one.
And I'd check the oil pressure sender wiring for shorts. The senders usually go bad by falsely showing low or no pressure, or leak. But abraded insulation on its wire, exposing conductor to ground, will peg gauge.
Old May 5, 2011 | 04:35 AM
corytcline's Avatar
corytcline
the tapping seems to be in the valves, like it is taking a long time to get the oil up there. It is full of oil and yes shows normal oil pressure.the check engine light will only stay on for a short while, and never comes back on when shut off again been trying to get the codes read but check engine light will not cooperate. Will keep trying though
Old Jun 29, 2011 | 07:00 PM
corytcline's Avatar
corytcline
yes the check engine light comes on now and never goes off parts house Auto Zone to be specific could not read the codes due to it is a 95 and they (auto Zone) told me they could only read 96 and up when ford put the OBD1 under the dash mine is not under the dash So I took it to a mechanic after finding an eec check point under the hood. Mechanic told me I had an electrical problem (DUH) and his code reader would not read it and he can not help me, sent me home. so back to the forums I go along with the light and the oil pressure gauge pegged (correct oil) I get fumes in the van kinda like rotten eggs and fuel when it does that it also puffs large amounts off black smoke and will barley pull it's self. Can anybody help me out thanks.
Old Jul 1, 2011 | 10:25 PM
Henry10s's Avatar
Henry10s
Like Club Wagon said, oil pressure gauge is a trouble-maker with these vans.
But your symptoms might really be related to a true oil pressure issue. Get a good oil gauge and measure the oil pressure at idle and 2500-3000 rpm. And do not drive the van until you know more what's going on.
Old Jul 5, 2011 | 05:29 PM
notmyrealname's Avatar
notmyrealname
The good old rotten egg smell is usually attributed to a bad O2 sensor.
Old Jul 5, 2011 | 09:51 PM
corytcline's Avatar
corytcline
currently not driving cut catylic converter off today did not help so its not a cloged converter did the self test on the eec under the hood all I could make out of it was codes for map/bp sensor, tps and act. Not sure where o2 sensor is on this vehical I looked in the exauhst pipe and saw nothing that looked like one to me( I have only changed one on a pontiac grand am though)
Old Jul 14, 2011 | 08:25 PM
corytcline's Avatar
corytcline
found o2 sensor got it changed unfortunitly nothing with the van changed other than check engine light stays on runs really choppy especially under acceleration when ideling will surge occasionally always with a puff of black smoke which also is preasent under acceleration when the van is running rough(it spits and sputters)
Old Jul 15, 2011 | 11:07 AM
98Econoline150's Avatar
98Econoline150
If it's black smoke, to me that sounds like fuel, not oil, so you may be dealing with multiple problems compounded by eachother.
Old Jul 15, 2011 | 06:36 PM
corytcline's Avatar
corytcline
I think it has something to do with fuel as well going to try fuel pressure regulator
Old Jul 16, 2011 | 09:31 AM
Club Wagon's Avatar
Club Wagon
At the very least check the fuel pressure regulator. A common failure is for the vacuum diaphram to leak, permitting gas to be drawn into motor by vacuum. Pull the vacuum hose off FPR & see if it's got gas in it.
It's also easy enough to check what the fuel pressure is to confirm if the regulator is maintaining specified working pressure.
Old Jul 16, 2011 | 11:36 AM
corytcline's Avatar
corytcline
Club Wagon I have never worked on one could you tell me where it is located so I don't mess with the wrong thing? What else could I check could throttle position sensor have anything to do with it?
Old Jul 16, 2011 | 08:16 PM
98Econoline150
IMHO I would suggest buying a service manual from Faxon Auto Literature. They are reasonably priced for original stuff. Link:
Search
provosc
32
Dec 1, 2017 12:59 PM
maf226
Feb 22, 2016 08:59 AM
1stonracday
2004 - 2008 F150
Oct 24, 2014 10:00 AM
igeorge
Feb 11, 2013 10:02 PM
JRROTH1
1997 - 2003 F150
Dec 15, 2009 08:27 AM
