Power window conv.
Old Mar 22, 2003 | 08:37 AM
73tank's Avatar
73tank
Power window conv.
Howdy all,
I have a 73 f250 that I would like to put power windows in. Since the physical makeup of the doors is similar throughout most of the 70's, would it be safe to assume that a donor in this time frame would supply me with parts that would basically bolt and go? assuming of course that 30 years han't taken its toll on the parts. Also if anyone had any wiring genious to impart upon me regaurding this application (what exactly will be required) that also will be greatly appreciated.
thanx
Old Mar 22, 2003 | 08:59 AM
kioolt's Avatar
kioolt
Power window conv.
I'm not sure but I don't believe that 70's Ford truck had power windows as an option.
Old Mar 22, 2003 | 09:58 AM
73tank's Avatar
73tank
Power window conv.
That would make it more difficult, wouldn't it.
Any other Ideas for donors?
Basically, I'm looking to do this on the low dollar so the wife won't kill me. I'm not afraid of a little fabrication. Maybe large for car motors with a little tweaking in the rail setup?
Old Mar 22, 2003 | 11:17 AM
steve83's Avatar
steve83
Power window conv.
You should be able to put in a later truck power regulator - that's what I did in this Bronco.
Old Mar 22, 2003 | 01:04 PM
Mil1ion's Avatar
Mil1ion
Power window conv.
We have a user heer (Weldman) who did this very conversion to
his 78 which is the same as the 73 .
I think he did a great job with it.
He hangs out on the Ontario Chapter forum.
Old Mar 24, 2003 | 10:04 AM
richierich45's Avatar
richierich45
Power window conv.
My first Ford Truck was a 1973 F250 XLT. It had power windows from the factory.
Look in a boneyard.
Old Mar 25, 2003 | 08:11 AM
73tank's Avatar
73tank
Power window conv.
to the boneyard I go!
thanx guys!
I'll be back with wiring issues for these I'm sure.
Old Mar 26, 2003 | 11:56 AM
Karic's Avatar
Karic
Power window conv.
73;
I converted my '86 F250 and used the motors out of a mid-70's LTD. I took all four so I had a couple of spares. Found the appropriate window regulators and it's still working, albeit I used one of the spare motors.
The power regulators are different from the crank-type, so you'll need those, but it seems all the motors are very similar, except for right and left. You'll need to drill out the factory mounting rivets and use 1/4" x 3/4" SS cap screws and nylock nuts to attach them to your doors.
When you get to the switch part, I used a set from an '89 Chev Van (they were free) and they covered the crank holes nicely. Make sure you get the wire harness for the switches as well. I didn't at first and the "crimped-on" wires kept falling off.
The second spare motor got used in my '95 F250........bolted right in.
The wiring is quite straight forward. I bench tested everything to find what went were, and then ran the power from the back of the cigarette lighter, which is hot all the time.
Hope this helps,
Rick
Old Mar 29, 2003 | 07:59 AM
73tank's Avatar
73tank
Power window conv.
Rick:
That was the answer I was looking for, Thanks man.
By the way, thats not too much juice to pull from the lighter? I was under the impression that a relay/ fuse setup needed to be put in? If not yipee for me , less crap!
Thanks again
Old Apr 1, 2003 | 07:56 AM
Karic's Avatar
Karic
Power window conv.
73;
I didn't even know relays existed when I did this conversion. I think the cigarette lighter/horn used a 15A fuse, and I'd put a 10A in-line fuse in the power feed.
Some of the other guys may have a different approach, but my neighbour bought the truck and it's still working as far as I know.
Having said that, I'd probably use a relay if I was to do it again, just to be on the safe side. There's lots of room under there to do what you need to do.
Good Luck,
Rick
ulev1st
18
Mar 13, 2014 09:23 AM
AzSuperDuty
Oct 29, 2012 01:45 AM
miserableloser
Oct 21, 2012 11:25 AM
stm250
Oct 19, 2007 09:58 AM
the Goat
1978 - 1996 Big Bronco
Jun 30, 2006 04:31 PM
