Grinding noise
Old May 4, 2011 | 09:03 AM
derbyhunter5's Avatar
derbyhunter5
Grinding noise
My truck has started having a grinding noise when driving. You can't hear anything with the window down going slow but with it up you can hear it in the cab. Checked brakes hubs both are good. Could this b the carrier bearing.
Old May 4, 2011 | 11:30 AM
jwhitetail's Avatar
jwhitetail
Take some wd40 and spray the carrier real good and take for a drive and see if it shuts up if so that's it, if not needle bearing in the front hub is some thing to check also, you can lock the hub in to check them while driving to see if noise changes.
