64 Short
Old May 3, 2011 | 06:49 PM
Shawns Fords's Avatar
Shawns Fords
64 Short
some of you know me from slick60s. Been busy doing other things and keep losing log info with a move for a new job etc etc etc anyway
I have been working this ol truck over since about 2005? I cant remember. Lot of custom work and I do it all my self.
64 F100 Short Bed CC
460 CI / C6 trans and 3.89 Gear in a 9"
Wing window elimination
Billet 6 guage instrument panel
Affordable street rod wiring harness with power panel
MSD ignition
Weiend intake
Holley 750 Vac sec
Sanderson headers through flortech Warlocks
Bad *** Aoogah horn
Had a friend make some covers for my bench seat with some 50resto material an ol friend gave me
lots more to list and lots more work to be done
here is a few pictures
the day I brought it home from Canon city Colorado
Some progress has been made
POR15 front Axle
Big Block all dressed up
Interior is slowly coming together
no wing windows
here is a link to the rest of my photos
1964 F100 project pictures by shawnstang67 - Photobucket
I also have a 69 Bronco and a 67 Mustang
Old May 4, 2011 | 12:17 AM
Wills1966F100's Avatar
Wills1966F100
Nice truck and great pictures. Looking good!
Old May 4, 2011 | 02:08 PM
Shawns Fords
Thank you sir. I havent been able to work on it all year due to the distance it is from me right now. Hope that will change soon. Really miss getting things accomplished on it.
Old May 5, 2011 | 12:06 AM
Wills1966F100
I havent been able to work much on mine either all year due to the distance mine is from me right now, except that distance is only about ten feet to the garage lol. Thankfully it's starting to warm up so I won't have so many excuses. I hope you can break free soon to make some progress on yours. I like the custom doors and windows on your truck. Where did you get the new windows?
Old May 5, 2011 | 01:06 AM
Shawns Fords
Thanks, im wishing my tax return would show the F up. I need it for the windshield, and to finish my bronco. I got my windows from bobs F100 parts, then bought my own power window kits from a local street rod shop "streamline hot rods" That was a tough project. I still have to make some adjustments and may have to go in and trim some more of the hinge pocket out.
Old May 5, 2011 | 10:47 AM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
I have a solid 460 sitting my garage I am now thinking about using becouse I have been un-able to sell it.
That motor you have looks mean sitting there.
Old May 5, 2011 | 11:56 AM
StevenhF100's Avatar
StevenhF100
Wow!! Very nice!
Old May 5, 2011 | 01:06 PM
Shawns Fords
She fits in there really nicely also. Almost like it should have been a factory build.
Old May 5, 2011 | 01:07 PM
Shawns Fords
Originally Posted by StevenhF100
Wow!! Very nice!
Thank you sir.
Old May 5, 2011 | 03:59 PM
Customcab's Avatar
Customcab
Unable to pull up pic's at my location due to weak company computer; but my question is what upgardes beyond engine perforamce are ya going with. i.e p/s p/b?
Old May 5, 2011 | 04:09 PM
Shawns Fords
I plan with power drum brakes, the front and rear drums all new with shoes, springs, rebuilt my wheel cylinders. I haven't gotten to a booster yet. I have tossed several ideas about power steering and have not decided on weather to stick with armstrong steering or go with something else. I may do an AC system someday, thats not as much of a need up here it doesnt get hot often.
Old May 6, 2011 | 09:58 PM
Customcab's Avatar
Customcab
I'm building a 64 F100 currently; In the prefab / mock-up phase; I'm running a 360 & C-6booster ; plus; power brakes on drums & power steering; with a tilt steering column from a 78 F100. My booster from a 70's F100, steering box 76 F100. Biggest issue so far converting the power steering; (Keeping straight axle).Remove the old manual cab bracket and added the brake pedal from the 76 F100 instead. Additionally added a 2 speed wiper motor with delay wipers as well.
Sorry no pic's; I'm old & slow. lol
Old May 6, 2011 | 10:21 PM
Wills1966F100
Good work on the windows. I like my wing windows but they have a tendency to whistle at me. Good luck with the bronco project. I had a 4" lifted '90 EB bronco and did a lot of work to that truck. I put new windshields in both trucks: bronco and F100. I got a tinted (blue stripe across the top) windshield for the F100 and I like it. I wish I had customcab's two speed delay wipers.
Old May 7, 2011 | 12:58 AM
Shawns Fords
I,m old and slow as well haha. I am curious on your power steering conversion. Thats two different worlds going from 64 to anything later. I have memory of a mid 80s chevy that had the same style pitman arm (drops down from the frame instead of a horizontal swing arm) in a lifted 2wd chevy. I would like to find out what chevy truck that came off of rather than run a jap toyota gear on it.
If I had taken pics of all of the stuff ive done over the years, I wouldnt have ever gotten anything done I have over 6 pages on photobucket of this truck and my 67 mustang has about 3 pages, ive owned the 67 since 1992 and its been gone through 3 times. Crazy how times have changed
I love wing windows also but this was a project/goal I set to challenge myself to finish it. I love the clean smooth look as well. The only way I would do it again is if someone wanted to pay me to do it. HA!
Old May 7, 2011 | 01:29 PM
Customcab's Avatar
Customcab
Used a standard F150 style power steering box; only two holes truely go thru the 64 frame; as I mention I've semi box that area to assist with strength. The lower forward mounting bolt on the PS is partically thru the lower frame rail'of the 64 frame. I've cut & mounted a tube type spacer bracket piece against the frame to hold the lower bolt. (This allow all three factory bolts to mount the PS to the 64 Frame. Since I'm placing a tilt steering column; I purchase a universal 36 spline (3/4") joint from Summit; The tie rod end (11/16") that attaches to the 64 steering arm (Curved shape bracket that's attach to the drivers side wheel) from Speedway; and got another tie rod (3/4") that will be machined down that bolts thru the pitman arm attached to the PS box.
Hope this makes sense!
