No Start 95 psd
Old May 3, 2011 | 03:33 PM
Metalmanti's Avatar
Metalmanti
No Start 95 psd
Hello everyone, I am new to this forum, but have owned my 1995 F250 psd, 5 speed, extended cab, diy 6637 air filter, for over a year now and it has run great till now. I drove it about 2 weeks ago and it ran fine, parked it for about a week and a half over spring break got back and it wouldnt start. I have researched the forum on this condition and I think i have narrowed it down to 3 potential causes, ICP, IPR or IDM.
Here is what I have done so far:
Changed oil
Changed Fuel filter (bowl is full)
HPOP reservoir is full
low pressure oil gage comes up after cranking
Tach is registering
batteries charged
Replaced ICP (pulled the plug and had oil in the connector)
Tried starting with the ICP unplugged and it still will not start but the CEL light does come on while cranking.
no smoke while engine cranking
Glow plug relay is working
I am at a loss and any help on narrowing down the problem would be great.
Thanks
Old May 3, 2011 | 03:38 PM
mq1shooter's Avatar
mq1shooter
CEL coming on, so it's throwing code(s)...do you have access to a PSD capable scanner / reader?
And post where you live....
Old May 3, 2011 | 03:39 PM
427 fordman's Avatar
427 fordman
Do you have any way to pull the codes? Could be the idm, but you should see a code if you can read it. Was it by chance outside sitting in the rain? Also, make sure the ipr wire plug is on.
Welcome to fte, more help will come, you'll get it.
Old May 3, 2011 | 03:41 PM
mq1shooter's Avatar
mq1shooter
Check your fuses....#22, unplug the fuel bowl heater....
Old May 3, 2011 | 03:46 PM
Metalmanti's Avatar
Metalmanti
mq1 shooter, CEL only comes on when I unplug the ICP, I forgot to mention the fuses but they check out ok.
Where and how do I unplug the fuel bowl heater?
I dont have a way to pull codes but will see if I can find a code reader. It was sitting in the rain, it has actually been really wet on this side of Washington this year.
IPR plug is connected.
Old May 3, 2011 | 04:07 PM
mq1shooter's Avatar
mq1shooter
Out of the engine...and I am having a brain Fart, but I think it's the spade connector....GOSH I hate loosing my mind!!!!.....
If not, someone will correct me.
Old May 3, 2011 | 04:18 PM
427 fordman
If it was sitting in the rain, I'd pull the idm and shake it to see if there is water in it.
Shooter, I'm sure that is the right one, the middle one iirc. My mind isn't any better though...
Old May 3, 2011 | 04:19 PM
Hussler's Avatar
Hussler
If CEL comes on then PCM has power so fuel heater is OK.
Pull the IDM and shake it for water intrusion.
Is there fuel in the bowl?
Old May 3, 2011 | 04:22 PM
Metalmanti's Avatar
Metalmanti
Fuel bowl is full, not sure where the idm is, is it located drivers side fender well next to the fire wall?
Old May 3, 2011 | 04:27 PM
Hussler's Avatar
Hussler
I don't have a current picture so look at this thread ...
https://www.ford-trucks.com/forums/1...is-my-idm.html
Old May 3, 2011 | 05:57 PM
Action4478's Avatar
Action4478
Does the CEL come on while cranking only when you had the ICP unplugged ?
Old May 3, 2011 | 06:04 PM
Metalmanti's Avatar
Metalmanti
Action4478
CEL only comes on when icp is unplugged and cranking engine
Old May 3, 2011 | 06:16 PM
Action4478's Avatar
Action4478
Originally Posted by Metalmanti
Action4478
Thanks ...
Old May 4, 2011 | 09:21 AM
Metalmanti's Avatar
Metalmanti
Thanks for all the input so far, I was busy with the kids baseball last night and couldnt check anything.
I will try to locate a scanner today and check the IDM tonight and let you all know how it goes.
Old May 4, 2011 | 02:57 PM
Metalmanti's Avatar
Metalmanti
quick update:
borrowed a autoxray code scanner and set it up for the truck and did a KOEO scan and it said vehicle not responding. Called my mechanic and he is sending over one of his guys to scan it after work.
I will post codes this evening.
Pulled the IDM and shook it and there is no sign of water intrusion.
