f1 front fender: cover plate??
i see replacement fender cover plates to cover the hole under the upper edge of the front fender (48-50) f1. what was it for? i've never had one on mine, do i need it? it's a trapezoid (if i rem. my geometry) shaped about 6" long. after some finish body work, will be putting my truck back together. just wondering about that hole. thanks, dick r.
my bad. on closer examination LMC and classic haulers sell a "fender cover plate GASKET set." guess it would be fairly easy to make a cover. sorry about the mislead on that one. LMC is on the left side (drivers) says for 51-52. haulers shows same gasket 51, 52 for right side in their pic. dick r.
My truck has the opening for the Magic-Air heater along with all of the duct work. My parts truck has a block-off panel that looks like a knock-out panel. It looks like it would be something that they broke out at the factory if the truck was slated to get the Magic-Air.
I think you could cut a piece of thin sheet metal and cover the opening by either gluing or riveting it in place.
Dan
Dan
As stated, it's for the fresh tube on the Magic Air heater. The cover is actualy screwed into the fender, if I remember correctly. It's not a knock-out plate. It's an actual cover that is stamped out of metal. You can make just a flat cover out of some sheetmetal if you're not concerned with originality.
I may have one or two of those covers. Stay tuned....
jvmcc
05-16-2012 06:46 PM
Jeff and Nicolle
10-11-2011 11:35 PM
GreatNorthWoods
25
09-21-2006 06:03 AM
Dirt Boy
15
06-14-2005 10:03 PM
