Which oil should I use????
Old May 2, 2011 | 10:03 PM
mr.fordneck's Avatar
mr.fordneck
1990 F150 5.0 4x4 195k miles. I would like to go with what the manufacturer recommends. Synthetic or conventional or blend. What viscosity? I bought valvoline synthetic 10W-30 but its so expensive and I want to be using the right oil. My truck has no owners manual.
Old May 2, 2011 | 10:15 PM
SideWinder4.9l's Avatar
SideWinder4.9l
I personally just use Castrol GTX....10w30 in the summer, and 5w30 in the winter...As the manual recommends...
5qts at wallyworld for $13.50....
Volvo92906's Avatar
Volvo92906
I always use Valvoline 10-40 although im sure it asks for 10-30. I do my 3000 mile oil changes and refuse to use anything but normal plain old oil. My truck doesnt burn any (although it does have a rear main leak) but it is cheaper than synthetic.
As sidewinder said Castrol GTX.. Ive used that when it was on sale cause I like their GTX anti sludge stuff. But I only stick between those 2 brands. Normally Valvoline though.
Old May 2, 2011 | 10:38 PM
timbersteel's Avatar
timbersteel
I agree with both Volvo and Sidewinder. Oil is a personal preference and everyone has thier own opinion and not everyone will agree with what another member uses.
Here are a few links that can provide a clearer idea on what type of oil.
https://www.ford-trucks.com/forums/1...ge-advice.html
The link underneath is lengthy, but was very clear on oil and filters.
https://www.ford-trucks.com/forums/1...il-filter.html
When you change oil, I would use a clean drain pan. Let it sit for several hours. After letting it sit(i do for @ least 5,8 even 24 hours), gently drain into a container you can dispose of used oil properly. Look @ the original drain pain for any sludge, bearing material, or foreign debris. You can really get an idea of how the motor is doing by looking @ the deposits left.
Hope this helps.
Rus01
6.4L Power Stroke Diesel
Jul 8, 2013 08:08 PM
lakewood
Dec 15, 2009 01:59 PM
flyguy2
1983 - 2012 Ranger & B-Series
27
Apr 6, 2009 10:15 AM
froger25
Jun 2, 2006 07:19 AM
NCF150
1997 - 2003 F150
Dec 30, 2003 10:04 AM
