32 valve Northstar
Old May 2, 2011 | 08:16 PM
Canty's Avatar
Canty
32 valve Northstar
Is it possible to swap these motors in our trucks? My local j-yard has a whole row of them. Is it a smart swap? Is it worth it when it comes to fuel vs. power vs. cost of parts? Thanks guys.
Old May 2, 2011 | 08:44 PM
MiddleNameMUD's Avatar
MiddleNameMUD
Anything is possible and those motors with the right build can put out an unbelievable amount of HP but why??? Don't be offended I would love one of those engines but not in a dent... But that's just me
Old May 2, 2011 | 08:47 PM
dentside250's Avatar
dentside250
from what i know they were/are put in primarily G.M. vehicles that are front wheel drive. i think finding a tranny to fit the application might be tough. these motors have some power but from what i understand are horribly for gas mileage,and that is in a sedan not a half to three quarter ton truck
thats all the input i got
Old May 2, 2011 | 09:30 PM
impalaslayer's Avatar
impalaslayer
get a DOHC out of a 99-01 cobra 03-04 mach1, marauder, or cobra.
Old May 2, 2011 | 09:34 PM
bsiebert's Avatar
bsiebert
Do it! Be different... Like dentside250 said the hardest part would be finding a rear wheel drive transmission for it. The second biggest headache you would run into is the wiring harness if it isn't available. Both of these issues are easily overcome and would be really cool if you accomplished this.
On Wiki it says that the LH2 Northstar was made for rear wheel drive vehicles, I don't know much more than this though. The LH2 was only made from 04 to 09 though. The question I ask is could you retrofit an older style L37 and LD8 Northstar to work with the LH2 transmission.
Old May 2, 2011 | 09:41 PM
ecidemon's Avatar
ecidemon
From what I remember, they have a unique bellhousing bolt pattern that only fits the FWD transmission, as well as accessory issues. Check out the GM swap boards for more info. I ran across the information while looking for information on the 4.7. If you're looking to swap in a GM, my money is on any of the LS series engines (vortec 4700, 5300, LS1, LS6, etc etc) which have a huge aftermarket and are pretty solid engines (for a GM), and are a smaller package than the 4.6/5.4, which is why I was looking into it.
Old May 2, 2011 | 10:07 PM
hasteranger's Avatar
hasteranger
yeah wiring, mounts, accessories, and transmission would be a pain in the *** to take care of. Youd have as much in it as a ls series engine, and the LS weigh less and have way more support.
Personally I'd rather see a ford motor in there, but to each their own.
Old May 2, 2011 | 10:53 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
While there are a couple of conversion for them. They are not up to service in a truck unless you just wanna drive around with a couple of beach cruisers in back. Or mild home depot runs.
You can get them to hook up to a V6 60 degree T700R4 easy enough. You will likely need to have 4.11 gears with 27 inch tall tires so it can have enough rpm to move the truck.
They are good motors I just don't see it being worth while becouse of the cost, and lack of real aftermarket like the 4.6 Ford.
Old May 3, 2011 | 08:25 AM
Melbatoast's Avatar
Melbatoast
Screw the cobra marauder motor. Get the teksid block out of the mark 8. All aluminum block with an 8 bolt main.
Old May 3, 2011 | 09:10 AM
zxwut?'s Avatar
zxwut?
All 96-98 Cobras had the teksid block.
Old May 3, 2011 | 09:30 AM
dkf's Avatar
dkf
Better off with a Ford modular IMO.
Old May 3, 2011 | 09:45 AM
muscletruck7379's Avatar
muscletruck7379
fiero... and a blower...
Old May 3, 2011 | 10:21 AM
PA74F250's Avatar
PA74F250
Those Northstar motors are head gasket blowers. I wouldnt waste my time. I have a DOHC 4.6 Teksid motor in my cobra and its a blast to drive especially supercharged w/ 4.30 gears. However I would never recommend it for a truck. They are too high strung and not enough low end torque. Neither the DOHC GM or Ford are truck motors.
Old May 3, 2011 | 10:27 AM
impalaslayer
the block IS NOT the weak point in any modular. stock 04 cobra blocks have been taking well past 1000hp and stock alum romeo blocks have been close tot he same with out any trouble
oh also, teksid have 4 bolt mains with one cross bolt per side totaling 6 not 8
the iron blocks and romeo blocks also use the cross bolt but only one 2 mains
Old May 3, 2011 | 01:33 PM
DKW 86's Avatar
DKW 86
Northstar problem history.
