Dummy plugs
Old May 2, 2011 | 07:00 PM
johnthoms's Avatar
johnthoms
Dummy plugs
Hey there fte. I got a simple question about the updated dummy plugs I am putting in truck now , there are two plugs one has two white Teflon o- rings the other has only one which goes where or was this tampered with thanks
Old May 2, 2011 | 07:20 PM
kenlippold's Avatar
kenlippold
They should be identical. Are your new plugs installed with a 1/2 square drive or the new updated allen?
Old May 2, 2011 | 07:30 PM
johnthoms's Avatar
johnthoms
They have Allen style head , just as a note the bag I got from my ford dealer had no holes or tears in it but one plug is different then other
Old May 2, 2011 | 07:34 PM
kenlippold's Avatar
kenlippold
I would take them back. I just replaced mine in March and they were identical from Parts Guy Ed.
Old May 2, 2011 | 07:42 PM
johnthoms's Avatar
johnthoms
Great thanks I thought it looked suspisious ,well gotta bring them back I should get a house next to dealer it would make life alot easier thanks
Old May 2, 2011 | 09:15 PM
jmaskew's Avatar
jmaskew
I have to ask... what are dummy plugs?
Old May 2, 2011 | 09:31 PM
tharepairguy's Avatar
tharepairguy
they go through the high pressure oil rail. The updated ones have a white teflon washer behind the o-rings.
Old May 2, 2011 | 09:41 PM
jmaskew's Avatar
jmaskew
Ah ok. I haven't dug that far into my engine...yet, that's why I haven't heard of them. Thank you.!!
Old May 3, 2011 | 09:47 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
.....and what IS their purpose?
Old May 3, 2011 | 07:01 PM
kenlippold's Avatar
kenlippold
It looks like the high pressure oil rail could be used on either side (not positive about this). You would have to reconfigure the dummy plug and stand pipe to do it.
Old Jul 10, 2011 | 09:18 AM
JSWdecks's Avatar
JSWdecks
Hi I'm new here, I'm having the same problem with my 05 250. The dealership wants $488 to replace the dummy plugs and $1164 for the STC fitting. I don't feel comfortable doing the work myself, what should I expect to pay from a local mechanic. Thanks in advance.
Old Jul 10, 2011 | 12:06 PM
cheezit's Avatar
cheezit
$1400-1600. basicly what the dealer charge is.
to the op you have one new style and one old. the teflon one is the updated part.
Old Jul 10, 2011 | 12:12 PM
johnthoms's Avatar
johnthoms
Thanks cheezit it was fords mistake there was a missing Teflon o ring on one of my dummy plugs they both had the 12mm hex head but just missing o ring so ford just gave me a new one
Old Jul 10, 2011 | 12:39 PM
smokersteve's Avatar
smokersteve
Do you have a friend that can help out?
There are many many individuals on here that are very capable to hlep you through it, along with many pictures.
Depending on where you get the STC it can be between $30 and $60
I got mine for $38.
Cheapest I have seen the dummy and stand pipe kit is ~$109
Old Jul 10, 2011 | 02:13 PM
JSWdecks's Avatar
JSWdecks
Thanks for the responce, I do have a neighbor that used to be a diesel mechanic, I haven't had a chance to ask him about it yet, he's been out of town and this just happened on Thursday (it's been running rough and died a couple of times earlier this week) Thursday was the day it got really bad.
I have checked out the parts from;
Ford 6.0 STC HPOP Fitting Update Kit
Ford 6.0 Updated Injector Rail Plugs AKA "Dummy Plugs"
Ford 6.0 Updated Stand Pipes
It looks like $250 for them, plus shipping.
I'm new to diesel trucks, I have owned 2- 5.8 gas 250's in the past, never had any problems with them, except a bad coil and wire.
Maybe I'll get a Haynes repair manual and check it out, unless you guys have a better one. Thanks again for the responce.
