Something Missing?
Old May 2, 2011 | 12:23 PM
wmjoe1953's Avatar
wmjoe1953
Exclamation Something Missing?
I am having issues with the original oil bath air cleaner for this '54 F-100. It is the correct air cleaner, and the carburetor is correct. I think something is missing, or something else is wrong, as I do not have another sample to look at, at this time. I cannot get the air cleaner base to fit tightly around the neck of the carb, and it has been numerous years since I dealt with the 239 in my fathers '55, which fits correctly. The air cleaner was off, on the cab floor when the truck arrived, and there was nothing on the neck of the carb. I can find nothing listed in the parts books, and nothing to indicate something is missing, but it doesn't seem to fit properly. I can get, and upload photos if neccessary, but is there anything, off the top of anyones heads, that you all can think of?
Old May 2, 2011 | 12:45 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Is the neck of the air cleaner V-shaped? some a.c.'s and carbs have straight necks as yours does, and most trucks have a wedge shape to better support the weight of the a.c. (hard to describe, do a search as I posted picture of the two types)
Old May 2, 2011 | 12:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Some oil baths have an adjustable clamp made as part of them that fits between the air cleaner and the throat of the carb. Has a handle that tightens it up.
What's that radio from? Looks like the deluxe type that was used in 1947/52 Studebakers.
Old May 2, 2011 | 05:07 PM
jbrittonjr's Avatar
jbrittonjr
Do you want to reinstall the oil bath cleaner? I seem to recall that they are more restrictive than paper.
Old May 2, 2011 | 05:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Back home now, here is a pic of the two types of necks on the carbs
Old May 2, 2011 | 05:50 PM
Harrier's Avatar
Harrier
You are most likely missing the clamp as NumberDummy said.
My carb neck is the other style but here is my setup off my 239.
Here it is installed.
Old May 2, 2011 | 06:00 PM
wmjoe1953's Avatar
wmjoe1953
I have the carb on the left, according to the post by Ross, and my air cleaner, and clamp are of the type pictured by Joe. Again, this air cleaner was just sitting on the floor, as in the picture I posted above, so I cannot guarantee it is the correct air cleaner, except that it looks like an original air cleaner.
Old May 2, 2011 | 06:02 PM
wmjoe1953's Avatar
wmjoe1953
I wonder, is it possible, since I do beleive the carb has been changed, is the incorrect carb on this truck? Should I have a carb that is like the one on the right, with the clamping ring, that loosely resembles an exhaust donut seal?
Old May 2, 2011 | 07:02 PM
Harrier's Avatar
Harrier
I don't see how the clamp would work on the carb on the left.
The clamp needs a lip to grab onto. I would guess you have the wrong carb for that air cleaner, but I'm far from an expert.
Old May 2, 2011 | 07:40 PM
51PanelMan's Avatar
51PanelMan
I believe that carbs from cars were smooth at the top like the one you have. Truck carbs had a ridge at the top as pictured Harrier's post. I would look for the correct carb and attachment clamp, if yours is missing.
Old May 2, 2011 | 09:41 PM
52 Merc's Avatar
52 Merc
I'm not sure if you have the wrong carb or the wrong cleaner, but either way, your parts don't match. I guess the good news is, you're not missing anything, necessarily. If you're not looking to be concours correct, you're in luck. All of the really cool aftermarket air filter units are designed to fit on your carb type. If that's the way you decide to go, your stock cleaner assembly may be the one I'm looking for for my project. We might be able to work something out there.
Old May 2, 2011 | 09:55 PM
wmjoe1953's Avatar
wmjoe1953
This truck is being restored stock, including an oil bath air cleaner. I suppose, I will have to drill some small holes, and install set screws to make it work. I understand what the problem is, but do not have a way to correct it at this time, unless some of you have the correct carb top you would be willing to part with.
Old May 2, 2011 | 11:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
"1952" or Vintage Speed can likely fix you up with the matching bowl cover, so you don't have to change the whole carb. Rebuilt carbs often came with the smooth (straight) style like you have, so did generic replacements.
Old May 2, 2011 | 11:24 PM
wmjoe1953's Avatar
wmjoe1953
I was wondering about that Ross. I know that I have two carbs with this engine. One is marked ECG, and is also a 1 1/16", while the other is marked EBU, and 1" Both have the same bowl cover, and I think that somewhere along the line, one got swapped, then another was picked up, and they both were wrong. That is the only thing that makes sense. I located another carb on ebay, and it's in Oregon, and has the top I need. For $20 somethin (currently) plus $10 shipping, I will get it, and change the top out.
I greatly appreciate the input, I was starting to wonder, since it's been more than ten years since the last time I laid eyes on a 239 with oil bath top. The last several dealings have been 279s, and 317s, and Caterpillars, and Cummins.
Old May 3, 2011 | 03:30 PM
wmjoe1953's Avatar
wmjoe1953
Yes, the old radio is a Studebaker/Philco. It's not going back in the truck. In fact, I think the owner will end up putting it on ebay, even though we have no clue if it works.
