new member needs help
Old May 1, 2011 | 08:26 PM
carver94f350's Avatar
carver94f350
Hello everyone. First off let me start by saying hi and tell you a bit about my ride. I've got a 1994 F350 Crew Cab long bed. It's 4wd, automatic, and it's an XLT, with a 7.5L motor. Also has some 16" Gear wheels with Maxxis 315/75/R16 tires on it, I got off Craigslist for about $300.00. It has about 106k miles on it. It's been run through and it's pretty much my fixer upper and needs some love.
First thing that it needs is some transmission love. It's almost dead. This is the first priority before anything else can happen. It's tricky, sometimes it works sometimes it doesn't. I took it to a company around the corner from my house and they said what I needed, but I can't remember now. Sometimes when I drive, it will slip out of gear and I have a helluva time getting it back in gear. Especially with a load. Basically they said it was gonna have to be completely rebuilt. They also said it was gonna cost about $2400.00. Well I don't have that kinda money in my pocket. I'm on a pretty tight budget so I'm thinking I'm gonna just rebuild it myself.
I'd like some thoughts or suggestions as to where I could get parts and stuff for a pretty decent price. That would help tremendously. I'm planning to pull the tranny and after that I'll start figuring out where to go from there. I'd rather just buy a rebuilt one if I can, but again budget is an issue, and besides that if I go to a "U-Pull it" place or a salvage yard I don't know how to tell if the tranny is good when I get it.
I'm by no means a mechanic, however, I am mechanically inclined. I can pretty much put back together anything I take apart. I'm especially good with instructions and pictures too. I'm sure most people are. So anything along those lines are greatly appreciated, and in the meantime I'll be searching google for some help as well.
Hope to get to know a lot of people on here, and thanks for any help as I get started on this adventure. At some point I'll start a build thread because I have lots of plans for this truck for family, work and most of all play.
Thanks, nice to meet you!
Old May 1, 2011 | 08:32 PM
punkandpissed138's Avatar
punkandpissed138
welcome to FTE man. haha, sounds like a nice truck given some love!!
Old May 1, 2011 | 08:33 PM
skyfox10's Avatar
skyfox10
Welcome to FTE. I know auto tranny rebuilds are not super simple, but there will be more people on this thread soon who can point you in the right way. First thing would be to ID your transmission. more than likely you have an E4OD, as most heavier trucks had that. I did run into a 94 last fall that had a C6 though, so it's not out of the question.
Also, the E4OD had a few week points which got addressed over the years, you will want to make sure to upgrade the internals when you rebuild so your transmission wont overheat or blow a seal.
punkandpissed138
post up some pics man haha
Old May 1, 2011 | 08:40 PM
skyfox10's Avatar
skyfox10
to ID your tranny, check out these resources
1. Ford Transmission Spotter's Guide - Extrememly Comprehensive guide to identifying ford transmissions.
2. Check your door tag. on the bottom it will have a transmission code. Yours should be one of the following
G = Ford C4 auto
K = Ford C6 auto
M = Mazda M5OD-R2
P = BW T-19 (early), or Ford C6 auto
T = Ford AOD auto
U = Ford 4R70W auto
W = Ford C5 auto, or ZF S5-42 HD Wide-ratio
Z = ZF S5-42
6 = ZF M6HD-6
7 = Ford E4OD/4R100 auto (Lightning)
9 = Ford E4OD/4R100 auto (diesel)
3. Here is a nice little guide based on the transmission pan shape:
Old May 1, 2011 | 08:48 PM
L. Ward's Avatar
L. Ward
Sounds like a decent deal! Parts alone are worth more than what you paid for it! (I paid $1000 for my 93 F350 CC) As for the tranny, its pretty straightforward to rebuild. I will throw this out at you though. IF the TPS switch is acting up, it will cause the E4OD to act up. It wont up shift, and all you will have is 1st and 2nd by shifting manually (ask me how I know, LOL). IF it does need a rebuild, you are going to be spending some cash regardless. Doing the upgrades are what really costs money. I lucked out on the E4OD in my 90. Picked up a FoMoCo reman unit with 50k miles on it for $500, swapped the fluid and still going strong 5 years later. Depending on where you are at, I would probably look at a used one. I did a quick look on car-part.com and found several 7.5 4x4 E4OD's, 1995 & 1996 models (all the upgrades already done) for $500-600.
If you are close, this one would not be a bad deal.
Transmission
Ford Truck 350 JASPER REMAND FLUID GOOD $650 Stups Auto Center USA-MD(Frederick) E-mail 301-663-6918 / 800-834-1548
Old May 1, 2011 | 08:49 PM
carver94f350
Wow, thanks for the quick responses guys! I'll get some pics taken soon and post em up. I'll take a look at the tranny and see what I can find. I'll take some pics of it too. The guys at the tranny shop said something between the 3rd and 4th gear was about shot? I'm horrible with terminology so please forgive me. Can't remember what they said, but it was something along those lines. Maybe that would help id my problem.
As far as upgrading, as long as I'm in there I'm all in for new parts. I like to do that anyway. If I tear something apart, I like to go back with new parts whenever possible.
Thanks again!
Old May 1, 2011 | 08:50 PM
punkandpissed138
heyuh...wheres the E4OD? hahaha...the E4OD is a 20 bolt pan btw. so count yer bolts
Old May 1, 2011 | 08:54 PM
carver94f350
I just went and counted and it does have 20 bolts on the pan. So does that make it an "E4OD"?
carver94f350
What's everyone using to do pictures? I use photobucket on my other forums, is that about the same here?
Old May 1, 2011 | 08:59 PM
punkandpissed138
yup yup you have an E4OD my friend..and to post pics...get the URL code of the picture and go to "POST REPLY" notquick reply..on the little image icons, look for the yellow one that has a mountain in it..click that and post the URL code into the appropriate slot
Old May 1, 2011 | 09:44 PM
skyfox10's Avatar
skyfox10
and now for the exploded diagram of the tranny...
1 Converter Assembly 7902
2 Plug Converter Drain ⅛" ??x27NPT 87650-S2
3 Shaft Input 7017
4 Seal Front Pump Support 7L323
5 Seal Front Pump E9TP-7A248-AA superceded by E9TZ-7A248-B
6 Bushing Front Pump 7B258
7 Seal Front Pump (O-Ring) 7A248
8 Bolt and Washer Assembly (Front Pump to Case) N805260-S
9 Washer Replacement (9 Req'd) 7G379
10 Pump Assembly Front 7A103
11 Washer Pump Thrust No. 1 7D014
12 Bearing Assembly Overdrive Sun Gear No. 2 7E486
13 Gasket Pump 7A136
14 Seal Coast Clutch (2 Req'd) 7G402
15 Cylinder Assembly Coast 7G387
16 Seal Coast Clutch Inner 7A548
17 Seal Coast Clutch Outer 7A548
18 Piston Coast Clutch 7A262
19 Ring Coast Clutch Piston Apply 7N519
20 Spring Coast Clutch Piston Disc 7B070
21 Ring Coast Clutch Disc Spring Retainer 7A527
22 Plate Coast Clutch Internal Spline Friction 7B164
23 Plate Coast Clutch External Spline Steel 7B442
24 Plate Coast Clutch Pressure 7B066
25 Ring Coast Clutch Pressure Plate Retaining (Selective Fit) 7D483
26 Gear Assembly Overdrive Sun 7D063
27 Ring Retaining 377155-S (Attaches Clutch Assembly Overdrive One-Way to Overdrive Ring Gear)
28 Ring Retaining 377300-S (Attaches Gear Assembly Overdrive Sun to Cylinder Assembly Coast)
29 Ring Retaining 377135-S (OWC to Outer Race)
30 Clutch Assembly Overdrive One-Way 7A089
31 Washer Overdrive Overrun Clutch Thrust No. 3 7L339
32 Planet Assembly Overdrive 7B446
33 Bearing Assembly Overdrive Planet Thrust No. 4 7F240
34 Gear Overdrive Ring 7A153
35 Shaft Overdrive Center 7A658
36 Ring Overdrive CL Pressure Plate Retainer (Selective Fit) 7D483
37 Ring Retaining 7G375 (Retaining Center Overdrive Shaft Assembly to Overdrive Ring Gear)
38 Bearing Assembly Overdrive Center Shaft Thrust No. 5 7G178
39 Plate Overdrive Clutch Pressure 7B066
40 Plate Overdrive Clutch Internal Spline Friction 7B164
41 Plate Overdrive Clutch External Spline Steel 7B442
42 Ring Overdrive Clutch Disc Spring Retaining 7A527
43 Spring Overdrive Clutch Piston Disc 7B070
44 Piston Overdrive Clutch 7A262
45 Seal Overdrive Clutch Piston Outer 7A548
46 Seal Overdrive Clutch Piston Inner 7F225
47 Ring Intermediate Cylinder Retaining 7D483
48 Bolt M10-1.5 x 24mm Overdrive Cylinder Fluid Feed 7Z059
49 Cylinder Overdrive and Intermediate Clutch 7G384
50 Seal Intermediate Clutch Piston Inner 7F225
51 Piston Intermediate Clutch 7E005
52 Seal Intermediate Clutch Piston Outer 7F224
53 Spring Intermediate Clutch Piston Disc 7B070
54 Bolt M12-1.75 x 31mm Center Support Fluid Feed (2 Req'd) 7Z059
55 Support Assembly Center 7A130
56 Washer Center Support Thrust No. 6 7L326
57 Seal Direct Clutch Cast Iron (2 Req'd) 7D025
58 Plate Intermediate Clutch Pressure Apply 7B066
59 Plate Intermediate Clutch Internal Spline Friction 7B164
60 Plate Intermediate Clutch External Spline Steel 7B442
61 Plate Intermediate Clutch Pressure Rear 7B066
62 Piston Assembly Intermediate Band Servo 7D021
66 Band Assembly Intermediate 7D034
67 Clutch Assembly Intermediate One-Way 7A089 (*)
68 Washer Intermediate One-Way Clutch Thrust No. 7 7G401
69 Drum Assembly Intermediate Brake 7D044
70 Seal Direct Clutch Piston Inner 7A548
71 Seal Direct Clutch Piston Outer 7A548
72 Piston Assembly Direct Clutch 7A262
73 Retainer and Spring Assembly Direct Clutch 7A262
74 Ring Direct Clutch Support Spring Retaining 7C122
75 Washer Intermediate Brake Drum Thrust No. 8A 7C096
76 Plate Direct Clutch Internal Spline Friction 7B164
77 Plate Direct Clutch External Spline Steel 7B442
78 Plate Direct Clutch Pressure 7B066
79 Retaining Ring Direct Clutch Pressure Plate (Selective Fit) 377126-S, 377127-S, 377128-S, 377437-S
80 Seal Forward Clutch Cylinder (2 Req'd) 7D019
81 Bearing Assembly Forward Clutch Needle Thrust No. 8B 7F374
82 Cylinder Assembly Forward Clutch 7A360
83 Seal Forward Clutch Piston Inner 7A548
84 Seal Forward Clutch Piston Outer 7A548
85 Piston Assembly Forward Clutch 7A262
86 Ring Forward Clutch Piston Spring 7D256
87 Spring Forward Clutch Piston Disc 7B070
88 Ring Forward Clutch Spring 377127-S (FWD CL Piston Spring to FWD CL Cylinder Assembly)
89 Plate Forward Clutch Pressure 7B066
90 Spring Forward Clutch Pressure 7E085
91 Plate Forward Clutch Internal Spline Friction 7B164
92 Plate Forward Clutch External Spline Steel 7B442
93 Plate Forward Clutch Pressure Rear 7B066
94 Retaining Ring Direct Clutch Pressure Plate (Selective Fit) 377127-S, 377437-S, 377444-S, 386841-S, 386842-S
95 Washer Forward Clutch Hub Thrust 7D090
96 Ring Forward Hub Retaining 377132-S (FWD Ring Gear Hub to FWD Ring Gear) No. 8C
97 Hub Forward Ring Gear 7B067
98 Gear Forward Ring 7D392
99 Bearing Assembly Forward Clutch Thrust No. 9A 7D234 (Between FWD Ring Gear and FWD Planet Assembly)
100 Washer Forward Planet Carrier Thrust No. 10A 7A166
101 Planet Assembly Forward 7A398
102 Bearing Assembly Forward Clutch Thrust No. 9B 7D234 (Between FWD Planet Assembly and FWD Sun Gear Assembly)
103 Gear Assembly Forward/Reverse Sun 7D063
104 Shell Input 7D064
105 Washer Input Shell Thrust No. 14 7D066
106 Ring Retaining 377300-S (Attaches FWD/REV Sun Gear Assembly to Input Shell)
107 Ring Reverse Clutch Pressure Plate Retaining 7D483
108 Plate Reverse Clutch Pressure 7B066
109 Plate Reverse Clutch External Spline Steel 7B442
110 Plate Reverse Clutch Internal Spline Friction 7B164
111 Spring Transmission Reverse Clutch Cushion 7E085
112 Ring Reverse Planet Retaining 377155-S
113 Washer Planet Carrier Thrust No. 10B 7A166 (Between Reverse Planet Assembly and Input Shell)
114 Planet Assembly Reverse 7D006
115 Washer Planet Carrier Thrust No. 11 7A166 (Between Reverse Planet Assembly and Output Shaft Hub)
116 Ring Retaining 387031-S (Retaining Output Shaft Hub to Output Shaft Assembly)
117 Gear Output Shaft Ring 7A153
118 Hub Output Shaft 7D164 (*)
119 Ring Retaining 377132-S (Retaining Output Shaft Hub to Output Shaft Ring Gear)
120 Hub Assembly Reverse Clutch 7B067
121 Clutch Assembly Reverse One-Way 7A089
122 Bearing Assembly Output Shaft Hub Thrust No. 12 7G178
123 Retainer and Spring Assembly Reverse Clutch 7D406
124 Seal Reverse Clutch Piston Inner 7D404
125 Seal Reverse Clutch Piston Outer 7D403
126 Piston Reverse Clutch 7D402
127 Bushing Case Front 7025 (3 Lube Grooves)
128 Case Assembly 7005
129 Vent Assembly Case 7034
130 Connector Assembly Fluid Tube Inlet (Front) 7D273
131 Bolt N605770-S36 (Attaches Heat Shield to Case)
132 Heat Shield 7A434
133 Valve Assembly Converter Drain Back Check (Rear) 7D174
134 Bushing Case Rear 7025 (1 Lube Groove)
135 Bolt (5 Req'd) 5/16 x 1.9 7D167 (One-Way Clutch to Case)
136 Washer Output Shaft Thrust Rear No. 13 7B368
137 Gear Output Shaft Parking 7A233
138 Output Shaft Assembly (4x2) 7060
139 Gasket Extension Housing 7086
140 Extension Assembly (4x2 except Super Duty) 7A039
141 Bolt Extension Assembly to Case (Top) (7 Req'd) N605803-S36
142 Bracket Wiring 7H102 (**)
143 Bolt Extension Assembly to Case (4x2 Bottom) (2 Req'd) N605802-S36
144 Bushing Extension Housing (4x2) 7A034
145 Seal Extension Housing (4x2) 7052
146 Plug Assembly Extension Housing 7H183
147 Screw and Washer Assembly 1/4-20 x .62 (Plug Assembly to Extension Assembly) 57621-S2
148 Output Shaft Assembly (4x4) 7060
149 Extension Assembly (4x4 and Super Duty) 7A039
150 Bolt Extension Assembly to Case (4x4 and Super Duty Bottom) (2 Req'd) N606569-S36
151 Indicator Assembly Fluid Level 7A020
152 Tube Assembly Fluid Filler 7A228
153 O-Ring Filler Tube 391308-S
154 Tube Fluid Inlet Short 7A160
155 Screw and Washer Assembly M8-1.25 x 23.8 (2 Req'd) N805232-S (Attaches 7D419 to 7005)
156 Plate Parking Rod Guide 7D419
157 Spring Parking Pawl Return 7D070
158 Pawl Parking 7A441
159 Shaft Park Pawl 7D071
160 Bolt M8-1.25 x 25.9mm N805261-S191 (Attaches Park Pawl Act Abutment to Case)
161 Abutment Parking Pawl Actuating 7G101
162 Nut 3/8 Spring 372552-S2 (Attaches Service ID Tag to Case)
163 Tag Transmission Service ID 7B148 (**)
164 Nut M10-1.5 Hex N620482-S2 (Attaches Manual Lever Assembly to Case)
165 Lever Assembly Manual Control 7A256
166 Bolt Assembly Transmission Range Sensor to Case (2 Req'd) N805312-S100
167 Sensor Transmission Range 7A247
168 Shaft Manual Control Lever 7C493
169 Seal Manual Control Lever 7B498
170 Pin Manual Lever Retaining 7B210
171 Rod Assembly Parking Pawl Actuating 7A232
172 Lever Manual Control Valve Detent Inner 7A115
173 M14-1.5 Hex Inner Detent Lever N800287-S36 (7A115 to 7C493)
174 Bolt Manual Valve Detent Spring Assembly to Case N805503-S
175 Spring Assembly Manual Valve Detent 7E332
176 Plug Test Port 1/8-27 Hex Head (2 Req'd) 390685-S (**)
177 Stud Valve Body Assembly to Case Solenoid Valve Body to Case Accumulator Body Assembly to Case N805330-S
178 Plug Converter Access 7N171
179 Ball Rubber Check (8 Req'd) 7E195
180 Stud Main Control Assembly to Case N805331-S
181 Spring EPC Blow-Off 7D017
182 Ball EPC Blow-Off 353351-S
183 Gasket Valve Body Separator Plate 7C155
184 Plate Valve Body Separator 7A008
185 Gasket Valve Body Separator Plate to Case 7D100
186 Screen Assembly Solenoid 7G308
187 Valve Body Assembly 7A100
188 Plate Valve Body Reinforcing 7F282 (**)
189 Bolt Valve Body Reinforcing Plate to Case (3 Req'd) N805503-S
190 Solenoid Valve Body Transmission Control 7G391
191 Bolt Solenoid Valve Body to Case (9 Req'd) N805329-S
192 Bolt Valve Body Assembly to Case and Accumulator Body Assembly to Case (18 Req') N805326-S
193 Bolt Valve Body Assembly to Case N805327-S
194 Nut Valve Body Assembly to Case Solenoid Valve Body to Case Accumulator Body Assembly to Case N805328-S
195 Control Assembly Accumulator Body 7G422
196 Gasket Transmission Pan 7A191
197 Screen Assembly Transmission Pan (4x2) 7A098 (*)
198 Pan Assembly Transmission (4x2) 7A194
199 Magnet Transmission Pan 7L027 (**)
200 Bolt Pan Assembly to Case N605902-S36
201 Screen Assembly Transmission Pan (4x4) 7A098 (*)
202 Pan Assembly Transmission (4x4) 7A194
* - Serviced only in kit
** - Not services separately
Old May 1, 2011 | 09:48 PM
punkandpissed138
wow....never really have seen a tranny in pieces...lotsaparts lol
Old May 1, 2011 | 09:55 PM
carver94f350
Well that's not overwhelming! LMAO!
Ok I'm uploading pics. After Dinner I'll post up.
Old May 1, 2011 | 10:07 PM
carver94f350
Here she is.
Here's the tranny
As you can see, she's a leaky ugly dirty mess.
