'69 has a lean?
Old May 1, 2011 | 03:24 PM
alvald83's Avatar
alvald83
'69 has a lean?
After washing my truck today, i stood back to admire it and noticed that it seemed higher on the driver side. I measured it - it was 1 1/4 difference. Can i assume its the leaf springs? Its an '69 F250.
Old May 1, 2011 | 04:04 PM
justforkicks's Avatar
justforkicks
a fatigued spring or a broken overload spring will cause a lean. check the passenger's side springs for any cracks or spacing.
Old May 1, 2011 | 07:34 PM
orich's Avatar
orich
you could also be in for replacing the spring eye rubber bushing to. I've had to do it 2 times now have the poly ones, but they do squeak but last for yrs. If your truck has ever had a camper on it then may be the reason for weak springs. I've had to replace my front springs a short time ago after the ad-a-leaf failed after 20 yrs. Aslo put in f350 rear spring about 15 yrs ago due a weak spring from having a camper on for many yrs. Weak springs seems to have been a common problem. But then look how old these truck our...
orich
Old May 2, 2011 | 04:55 AM
Talltruck's Avatar
Talltruck
Depending on what kind of shape the body mounts are they can be rusted out or the rubber can be deteriorated causing it to sit lower on one side. Take a look underneath to see how the mounts where the cab bolts to the frame are. While you're under there you can look at the spring mounts and bushings.
