2001 Excursion Electrical Spikes while driving
Old May 1, 2011 | 02:22 PM
Smukm's Avatar
Smukm
Hi Everyone,
I'm new to the forum and recently picked up a 2001 Ex XLT V10 2wd. Im loving it....I noticed however that sometimes while driving at night the speedometer needle spikes up. It does this when I turn the lights on as well, they spike...other times the right turn signal green arrow will come on stay on for about a min and turn off.
Anybody have an idea what this could be?
Thanks for your help in advance.
Old May 1, 2011 | 07:40 PM
jh818's Avatar
jh818
Welcome and congrats on your recent purchase.
Regarding the speedometer spike, it could be your vehicle speed sensor (VSS) located on top of your rear differential. It could be bad. Your cruise control may be also affected. Easy fix.
Not sure about your other problems. Someone will chime in.
Old May 1, 2011 | 08:44 PM
Smukm's Avatar
Smukm
the speedometer spike is usually paired with a flicker of head lights or the right turn signal light stays on as well as the turn signal light on the car. It stays on for 1 min or so but it happens 2 to 3 times in a trip. Not sure if they messed something up when they installed the custom Carbon Fiber center console. I haven't had an issue with the cruise control though.
Old May 2, 2011 | 09:35 PM
Smukm's Avatar
Smukm
bump ...for more potential help
Old May 3, 2011 | 01:52 AM
loleuiha's Avatar
loleuiha
Maybe Loose plugs in the back of the Instrument cluster??? Id check there if you havent..
Laki
Old May 3, 2011 | 06:24 AM
TurboRich$'s Avatar
TurboRich$
voltage regulator?
Old May 5, 2011 | 01:02 AM
Smukm's Avatar
Smukm
Originally Posted by TurboRich$
voltage regulator?
Turned it on tonight and noticed that my right head light was dipped the right turn signal light was on until I drove it a few yards before the headlight came back.
Sounds like a voltage problem on my right side only...
speakerfritz
Jul 25, 2018 12:00 PM
JamesMcMn
Nov 5, 2016 04:56 PM
grec-o-face
Nov 17, 2014 02:38 PM
Josh S
1983 - 2012 Ranger & B-Series
Sep 11, 2013 08:47 PM
SpokaneJim
Mar 14, 2012 10:11 AM
