Won't start.... PLEASE HELP!
Old May 1, 2011 | 01:26 PM
ExdrivinMom's Avatar
ExdrivinMom
Angry Won't start.... PLEASE HELP!
Hi Guys- our Excursion won't start, can you please give me some ideas what we can look for? It's an '03 with 243K. We purchaswed it 7/10, it needed an injector in November, other than that, it hasn't been a problem. We've done regular oil changes every 5K mi and have been replacing the fuel filters and air filter as recommended. We usually only drive it once a week, it was started and moved several times in the driveway on Thursday. My husband checked the batteries as well as the starter and both are fine. When inserting the key and turning to on, everything powers fine, the glow plugs start, but the engine won't crank when turning to start. There is no clicking.... nothing. Please give me some ideas as to what to look for... it's sitting in his aunt's driveway and needs to be moved before tomorrow night. I hate to have it towed 35+mi for something he could've done. Any help is appreciated.
Old May 1, 2011 | 01:29 PM
BLADE35's Avatar
BLADE35
check the fuses
Old May 1, 2011 | 01:30 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Also, here is a check list for "No Start"
https://www.ford-trucks.com/forums/8...condition.html
Old May 1, 2011 | 01:33 PM
ExdrivinMom
How do you check the black box type fuses? He checked the regular fuses visually, or do you recommend using a mutimeter?
Old May 1, 2011 | 01:36 PM
cheezit's Avatar
cheezit
thoses boxes are not fuses they are relays.
Old May 1, 2011 | 01:40 PM
ExdrivinMom
Is there any way to check the relays?
Old May 1, 2011 | 01:42 PM
cheezit's Avatar
cheezit
try google. search for relay testing. we dont have many relay issues.
does the ficm click when you cycle the key? start there.
Old May 1, 2011 | 01:47 PM
ExdrivinMom
FICM? What's that, where is it located? Sorry, dumb girl here. Thanks.
Old May 1, 2011 | 02:18 PM
amdriven2liv
FICM is on Driverside near firewall:
Old May 1, 2011 | 02:20 PM
amdriven2liv
Here is where you can get these types of photos of your motor.
Powerstroke 6.0L Technical Intro Manual
Old May 1, 2011 | 02:30 PM
BLADE35's Avatar
BLADE35
look on the fan shroud at the wires where the fan clutch plugs in for chaffing
Old May 1, 2011 | 04:22 PM
2006powerstroke90's Avatar
2006powerstroke90
A friend of mine had an 03. One day he called me up an says my truck won't start. He said everything was looking good, gauges, injector buzz etc.
Just when he turned the key it did nothing, no clicks.
Turned out a fuse blew. Put a new one no problems since.
It was a fuse under the kick panel
Old May 3, 2011 | 12:46 PM
ExdrivinMom
So my husband and a friend seem to think it's a bad solenoid on the starter. There was a spark there when moving one of the wires. Can the solenoid be purchased alone or do I need to buy a whole new starter and solenoid? None of the parts stores around here sell them separately.
Old May 3, 2011 | 02:32 PM
mixerdrvr's Avatar
mixerdrvr
If there was a spark when moving a wire, i would check for loose wires!!!
Old May 18, 2011 | 09:14 PM
ExdrivinMom
Hey Guys... I thought I'd just check back in with you. It turned out to be a bad connection between the solenoid and the starter... that's what caused the spark. Weird thing was that when he took the starter off earlier in the day and took it to the parts store, the starter passed the test? Don't know about that, would've thought if the connection was bad it would've failed the test. Anyway... I also wanted to add that if you need a starter, it pays to call around and check prices. The national guys all wanted about $200 with a lifetime warranty, but our local independant store uses a company out of MO and theirs was $130 with the same lifetime warranty! Thanks for your help!
