Rear end noise
Take a 3/8' drive extension, insert it into the square hole and unscrew the plug. Some fluid should spill out, if it doesn't you need to add some. (I misremember the type, 75w140 synthetic I think..if someone could help me out here....)
As for vibration if it's been there since the job was done they may have forgot to realign the driveshaft properly when they changed the pinion seal. Crawl underneath to see if they marked the driveshaft to the pinion and got the lines all on the same plain.
ffice
ffice" /><o
></o
><o
> </o
>I would not recommend this shop to anyone. Not only did he do this, but he did a transmission flush and front brake job after I told him not too. He then played the pity card saying “well the job was done” so, I should be paid. I argued a bit and he played the “I didn’t think you were that kind of guy.” What a joke…<o
></o
><o
> </o
>Anyway, thanks for the input.<o
></o
ffice" /><O
></O
><O
> </O
>I would not recommend this shop to anyone. Not only did he do this, but he did a transmission flush and front brake job after I told him not too. He then played the pity card saying “well the job was done” so, I should be paid. I argued a bit and he played the “I didn’t think you were that kind of guy.” What a joke…<O
></O
><O
> </O
>Anyway, thanks for the input.<O
></O
>Sorry to hear you were robbed by that idiot. He didn't deserve a dime from you.
