Hinge mirror installation?
Old Mar 19, 2003 | 07:16 PM
Karm's Avatar
Karm
I got a set of hinge pin mirrors for my '52 F-1, they are the ones with the curved rod. Anyway, I've heard mixed things as to how install them. Before I do it the wrong way, how exactly do you install them? I've heard everything from needing to grind a little off the hinge to having to hone out the hole a little bit.... I only want to do this once
Old Mar 19, 2003 | 08:05 PM
cobraii's Avatar
cobraii
Do you have any pictures of your mirrors I did not get any with mine. just the bracket.
Old Mar 22, 2003 | 09:13 AM
51f1's Avatar
51f1
1) Grind the heads off of your original pins.
2) Center punch and drill into the top of the pins. Use a diameter just a few thousandths smaller than the pin. Be sure you're not getting into the hinge. Drill into the pins approx. .25".
3) Soak with penetrating oil and have a beer.
4) With a punch, drive your old pins down and out of the hinge.
Good luck!!
