Brakes
Old Mar 21, 2003 | 03:22 PM
sternal2000's Avatar
sternal2000
Brakes
Whats the stock bore size on a 93 F150 for the master cylinder? I'm looking to upgrade mine to something bigger so I can push more fluid to my rear brakes (which are disc). What other master cylinders can i use and what will fit onto my booster?
Old Mar 21, 2003 | 04:15 PM
mantta's Avatar
mantta
Brakes
I have the specs for a 1990 and the piston has a 1" bore. Yours is more than likely the same. Keep in mind, when you enlarge that cylinder, it will require more braking pressure to get the results you had with the stock master cylinder. You move more fluid but, it takes more pressure to get results like you had.
