Tuning ?s
Old Apr 30, 2011 | 05:16 PM
arkredneck's Avatar
arkredneck
Tuning ?s
So I have a dP tuner chip that has the 80 100 120 140hp settings and this chip burnt for stock hpop and stock turbo and stage 2's. Would getting the chip reburnt for a 17 degree hpop and a d66 matter that much???
Old Apr 30, 2011 | 05:49 PM
arkredneck's Avatar
arkredneck
Is it worth the $80 to get the chip reburnt?
Old Apr 30, 2011 | 10:43 PM
oldbird1965's Avatar
oldbird1965
When I got the adrenaline and D66, TW told me I didn't need a reburn. The reburn was free so I made up some other reasons why he should fine tune it. I don't know that it made any difference.
Old Apr 30, 2011 | 11:18 PM
Talyn's Avatar
Talyn
the 15-17° wont make a difference.
Turbo wise it is possible, but with a d66 (which i would never buy) you could probably tweak the tuning slightly.
Old May 1, 2011 | 11:15 AM
arkredneck's Avatar
arkredneck
Whats wrong with a d66?? From what I read it does good with stage 2s
Old May 1, 2011 | 11:28 AM
Talyn's Avatar
Talyn
They are hit or miss from what I've read. and after Glenns trouble with his D66 and beans.......
Old May 1, 2011 | 12:03 PM
oldbird1965
That's not completly true Talyn. Last summer I had a lot of troubles but it was because of the up pipes leaking. That being solved, I think the D66 is preforming quite well.
As far as Bean goes, he has lousey customer service and when I was voiced that opinion to him he flat out told me that he was happy that I'm no longer a customer. IMHO, that is no way for a professional business man to conduct himself!!
Old May 1, 2011 | 12:13 PM
Talyn's Avatar
Talyn
Well, the question is, Are you truly happy with your D66 or not glenn?
Old May 1, 2011 | 12:29 PM
arkredneck's Avatar
arkredneck
I have only drove my truck a few times with the d66 but it stronger than stock it's building boost faster and will peg out the 30psi gauge I got very easy I'm just wondering if tuning would help more and for some reason the truck won't run on 80hp econo mode
Old May 1, 2011 | 06:45 PM
Talyn's Avatar
Talyn
yeah, the D66 should easily make 30 psi if I can make 30 psi with my stock turbo.
No idea on the tunes...?
Old May 1, 2011 | 07:13 PM
arkredneck's Avatar
arkredneck
Well it seems to build boost faster with less throttle and sounds better
Old May 1, 2011 | 07:28 PM
Talyn's Avatar
Talyn
I'm going to drop in a 38r.
Old May 1, 2011 | 09:20 PM
oldbird1965
Yes I'm happy but the biggest problem is I can't compare to others. I hit a 40 mph head wind in Ne last week and, like said, it spools really fast and hangs right in there. My EGT's aren't as high as when I had the stock one on. I know the coolingmist is helping but a few times I ran out of water and didn't want to stop but the EGT's were not that bad.
Old May 2, 2011 | 10:06 AM
MagKarl's Avatar
MagKarl
Really? Why?
Old May 2, 2011 | 10:21 AM
superduty4x4's Avatar
superduty4x4
Originally Posted by MagKarl
Really? Why?
Because he's a glutton for punishment and won't listen to the advice to skip the SD conversion and put a real turbo in that rag of his.
